1968 Center Console
Old 04-25-2014, 01:07 PM
68bluecoupe
68bluecoupe's Avatar
Default 1968 Center Console
I have a 68 Coupe with factory console, it's pretty beat up and the previous owner hack it up good putting in a single DIN radio.
I am thinking about just taking it out. What all would need to be replaced to go back to the stock look without the console? I would like to have a idea before I pull it out.
Thanks
68bluecoupe is offline
Old 04-26-2014, 01:43 AM
barnett468
barnett468's Avatar
Thanks
the big housing that holds the shifter. the indicator plate and chrome bezel.
you can also modify your housing
the shifter so it can hold your shift lite.
barnett468 is offline
Old 04-26-2014, 11:16 AM
68bluecoupe
So there isn't any difference in the shifter itself?
Old 04-27-2014, 06:05 AM
barnett468
barnett468's Avatar
there is a difference. the non console shifter has a bracket to mount the lite. the console shifter has an arm for a plastic rod to move the lite otherwise they are the same.
Old 04-27-2014, 11:00 AM
fastbackford351
Foghorn Leghorn
fastbackford351's Avatar
I'm almost certain you can use a console shifter with the non-console bezel. The little tabs don't stick up too far. If it won't, please don't go hacking it up to make it fit. It should be easy enough to trade with someone looking to install a console.
fastbackford351 is offline
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: 1968 Center Console
