lopey idle
Old 05-04-2014, 07:39 PM
rogan01
rogan01's Avatar
Default lopey idle
What is lopey idle and why is it good - or bad?
E.g the new frpp track key is supposed to allow this.
rogan01 is offline
Old 05-04-2014, 08:50 PM
jz78817
jz78817's Avatar
back in the day (like, way back[/i]) having a V8 with a lopey idle meant you had a hot camshaft (long duration/overlap) in it. now that we have variable cam timing, it's mostly for show.
jz78817 is offline
Old 05-04-2014, 10:03 PM
rogan01
rogan01's Avatar
Thanks but what exactly is it? Is it basically a rough idle? Is there a chance of stalling if idle drops too much?
rogan01 is offline
Old 05-05-2014, 10:54 AM
rogan01
rogan01's Avatar
Sounds like a problem? Based on searching it. Still don't know what it actually is though... Why would the track key let you set this rough idle on purpose? Thinking not much knowledge out on this...
rogan01 is offline
Old 05-05-2014, 11:18 AM
ffk_pennywise
ffk_pennywise's Avatar
Its exactly what it sounds like. A rougher sounding idle instead of smooth. Its more sporadic sounding. Its mostly for sound nowadays. Its sounds like old school muscle. Its not a problem. I have aftermarket cams installed that give my 07 lope. Here is a clip of a 2013 w/ track key engaging the lopey idle.
ffk_pennywise is offline
Old 05-05-2014, 12:04 PM
rogan01
rogan01's Avatar
Thank you sir. Excellent!
rogan01 is offline
Old 05-05-2014, 12:43 PM
ffk_pennywise
NP. I should have added that I don't know if there's a performance benefit using the track key or not, but with aftermarket cams that add lope, the driving force behind installing them isn't the sound but the power addition. The sound is icing on cake.
Old 05-05-2014, 01:57 PM
rogan01
rogan01's Avatar
I purchased a 2014 and frrp is releasing a track key like the one for the boss. Does other tune things but the idle is one. Have not heard of anyone that has it yet or reviews but sounds good and should be ford approved. Thanks again for your kind help and the video. Hoping it is like that.
rogan01 is offline
Old 05-06-2014, 06:21 AM
steel pony
steel pony's Avatar
The 5.0L engine in the 11+ Mustangs uses a newer technology called Ti-VCT Twin Independent Variable Cam Timing.
Here's an interesting article on the inner workings of the newer 3.7 & 5.0 engines
http://www.fordmuscleforums.com/2011...echnology.html
What the track key does (as well as aftermarket tuners) is reprogram the PCM for more spirited driving, different, more aggressive shift points, etc.
Unique to the Ti-VCT technology, tuners are able to overlap the timing on the oem cams, thus producing the "lope" that you hear in the previous video. Older 4v and 3v engines are forced to replace the cams to produce the same effect, since the cams are dependent on working together.
There is no real gain from the overlap (also called a ghost cam) on the 11+ it's all for the "cool factor". Whereas replacing the cams on the older engines will produce HP gains.
Ford Racing does sell the BOSS 302 Intake and Exhaust cams which will give you a slight bump in power...but why spend the $1000 for them when you can have the same sound for $250 =)
steel pony is offline
Old 05-06-2014, 09:16 AM
jsimmonstx
jsimmonstx's Avatar
The idle lope comes from changing the duration of intake and exhaust valve overlap, usually so that the intake valve stays open a little longer and or the exhaust valve opens earlier. That's easy to do on a the 5.0 (with the computer) because the intake and exhaust cams are separate. On a pushrod engine, there's only one cam that controls all of the intake and exhaust valves, so the cam has to be ground to certain specs to get that type of idle, and once installed, the only way you can change it is to change the cam.
There are two ways you can get a lope in your idle - change the cams, and/or apply a "ghost cam" tune. If you're only after the sound, get the tune. If you want an actual boost in power, get the cams.
jsimmonstx is offline
Quick Reply: lopey idle
