Rocker panel question
Old 05-06-2014, 08:25 AM
jimbir
jimbir's Avatar
Default Rocker panel question
I have a 2006 convertible. How do I remove the plastic covers from the rocker panels? Are here any pictures or you tube videos showing how to do this?
Thanks. Jim B.
jimbir is offline
Old 05-06-2014, 09:23 AM
edwin108
edwin108's Avatar
This manual for the Roush kit shows how to remove the factory molding: http://www.roushperformance.com/part...009-401337.pdf
edwin108 is offline
Old 05-06-2014, 10:30 AM
jimbir
jimbir's Avatar
Thanks. I've pulled the two front and all the bottom pins but the molding won't budge. The instruction don't say exactly what to do next and I don't want to break anything.
jimbir is offline
Old 05-08-2014, 06:52 PM
jimbir
jimbir's Avatar
Maybe I should ask this question. If I get the moldings off the rocker panels, will this allow me access to the inside of the panels? After it rains, I can hear water sloshing around. I'm assuming this is in the rocker panels. After the rain stops, it takes days for the water to stop dripping out of the drain slots. I've checked them with a piece of wire and they appear to be open. what sholld I do next?
jimbir is offline
Old 05-08-2014, 08:10 PM
AzPete
AzPete's Avatar
Possibly water in the doors.....many Mustangs have that issue.
AzPete is offline
Old 05-10-2014, 09:51 AM
jimbir
jimbir's Avatar
So, looking at the car, I noticed it has a cool rake with the front lower than the back. I drove it up on on some ramps to get the rocker panels slanted front higher than the back and, voila, the trapped water poured out the drains. No more sloshing. If you can park your car with the front end up hill, you won't need ramps.
jimbir is offline
chrisdbassplayer
10-13-2015 06:53 PM
b8checker
10-08-2015 12:55 PM
b8checker
09-30-2015 07:11 AM
Sixer4Life
09-28-2015 07:05 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Rocker panel question
