Anybody ever change rod bearing with the engine in the car
Old 05-15-2014, 06:45 PM
WJL
WJL's Avatar
Default Anybody ever change rod bearing with the engine in the car
Looks like i may have hammered her a little bit to hard, got a ticking in number six cylinder, goes away if i pull the plug wire, starts ticking around 2K RPM and higher. I thinking its a rod bearing
I figure i will drop the pan and pull the rod cap and measure the crank just for the fun of it. Searched the forum but couldn't find anything on this subject
Anybody ever successfully accomplish this?
WJL is offline
Old 05-16-2014, 07:39 AM
VTX1800N1
VTX1800N1's Avatar
No reason why you can't if the crank isn't torn up. Hardest part will be to R&R the oil pan. Much more difficult if it's one of the rods above the K member.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 05-16-2014, 03:10 PM
WJL
WJL's Avatar
i think if i get the motor up 3 or 4" i should be able to get to them, we'll see tomorrow
WJL is offline
Old 07-01-2014, 07:50 PM
WJL
WJL's Avatar
FYI I ended up taking the motor out, here's some pics
Attached Thumbnails Anybody ever change rod bearing with the engine in the car-picture-035.jpg   Anybody ever change rod bearing with the engine in the car-picture-040.jpg   Anybody ever change rod bearing with the engine in the car-picture-044.jpg   Anybody ever change rod bearing with the engine in the car-picture-049.jpg   Anybody ever change rod bearing with the engine in the car-picture-063.jpg
Anybody ever change rod bearing with the engine in the car-picture-050.jpg   Anybody ever change rod bearing with the engine in the car-picture-082.jpg   Anybody ever change rod bearing with the engine in the car-picture-084.jpg
WJL is offline
Old 07-02-2014, 01:28 AM
VTX1800N1
VTX1800N1's Avatar
Did you check all the rod bearings? May as well as long as you have the engine out. I'd pull the main caps and have a look there too. Will have to replace the bolts, though.
Old 07-02-2014, 02:49 PM
WJL
WJL's Avatar
I did replace all eight, i was going to pull the mains but decided not to based on i plan on pulling the motor and trans in the fall and do a complete rebuild. i just want to drive it for the summer so i thought i would take the chance. i have other pics if anyone is interested i did plastagage all the rod journals and all were within spec. FYI i got the connecting rod bolts from FORD $2.50 ea. which i though wasn't too bad
WJL is offline
Old 07-07-2014, 03:59 PM
WJL
WJL's Avatar
Well she is up and running, so far so good here's a couple more pics
Attached Thumbnails Anybody ever change rod bearing with the engine in the car-picture-071.jpg   Anybody ever change rod bearing with the engine in the car-picture-073.jpg   Anybody ever change rod bearing with the engine in the car-picture-008.jpg
WJL is offline
djbigskrilla
09-20-2022 01:04 AM
Jskeezy84
09-08-2015 01:40 AM
mweiland
08-13-2015 05:11 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: Anybody ever change rod bearing with the engine in the car
