05 gt p0191 error code
Old 05-24-2014, 10:29 AM
monera05
monera05's Avatar
Default 05 gt p0191 error code
Hey guy's
Been posting on many forum in regards to my issue here
Before I take it into ford.
Issue is p0191, p1237 and the pump is constantly running with the key on (no engine start) but yes it turn off once key is off ,
as the chart below shows i'm seeing 75psi at the fuel rail, and pump is at 0.75 duty (150%?)
can anyone look at this data log and tell me if the pump seem to be bad , i see negative values at the pump, but the tables (pcm and fpdm) is giving positive voltage
Before i take it into ford just wanted some of y'all professional advise!
Thanks!
monera05 is offline
Old 05-24-2014, 10:57 AM
moosestang
moosestang's Avatar
Does the car start? The pump runs and runs with the key on, engine off? It could be the fpdm or even the fuel pressure sensor
moosestang is offline
Old 05-24-2014, 11:23 AM
moosestang
moosestang's Avatar
this turned out to be a short to ground with the pump, but my money is on the fpdm.
Old 05-25-2014, 08:59 AM
monera05
monera05's Avatar
fpdm and fps have been replaced
car runs perfectly fine
monera05 is offline
Old 05-26-2014, 01:03 AM
Simon1
Simon1's Avatar
Most of the twin pump set ups I've seen with issues usually come down to some type of wiring issue. Either bad ground or too small of wire. Just a guess.
Simon1 is offline
Old 05-26-2014, 04:17 PM
moosestang
moosestang's Avatar
He doesn't have a twin pump. If the fpdm and fps have been replaced, then that only leaves a short in the pump or a short in the wiring.
Old 10-16-2014, 01:11 AM
drumhedd2005
drumhedd2005's Avatar
Im having the opposite problem. I keep getting the same code on my 05' GT. The pump stays on for a second when i turn key on (normal) but it starts REALLY HARD. Other times it doesn't start hard. It idles perfectly normal with no backfiring or missing. I replaced the fuel pump in Sept 2012, fuel filter was replaced about 2000 miles ago, I cleaned the MAF sensor, replaced spark plugs, and also replaced the fuel rail sensor. The car hesitates sometimes when I press down on the gas (not jumping on it) which is triggering the code. Its almost as if something is causing the fuel pressure to "hiccup." Any ideas????????
drumhedd2005 is offline
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
TCStangerv6
10-11-2015 05:57 PM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: 05 gt p0191 error code
