2006 GT axle ratio
Old 05-24-2014, 06:20 PM
Rubicon
Rubicon's Avatar
Default 2006 GT axle ratio
I recently purchased a 2006 GT Convertible with an automatic and the original owner left the window sticker in the glove box. I cannot find the axle ratio on that. Is there another easy way to figure out what axle ratio I have?
Rubicon is offline
Old 05-24-2014, 07:24 PM
JimC's Avatar
There should be a tag on the rear differential that lists the gear.
JimC is offline
Old 05-24-2014, 10:35 PM
Art161
Art161's Avatar
Unless you have reason to think the axle ratio was changed after the car left the factory, check the label on the door jamb, assuming the label is still there. I don't have '06 information, but I am not aware of changes in coding between '06 and the '07 information I have. CG is 3.31 with limited slip.
Art161 is offline
Old 05-25-2014, 01:31 AM
drewsky
drewsky's Avatar
CD on the door sticker is a 3:55 I know. The sticker on the differential itself is most likely still there as well.
drewsky is offline
Old 05-25-2014, 07:52 AM
steel pony
steel pony's Avatar
All Autos came with 3:31 standard
Only the Manuals had the option of upgrading to 3:55
steel pony is offline
Old 05-25-2014, 12:31 PM
Rubicon
Rubicon's Avatar
OK, I looked on the door jamb, CG is the axle code
I was wanting to switch to 4.10 gears, I have to research and see if I need a new carrier or just maybe only go to a 3.73 I will see if the AM chat team is available to help
Rubicon is offline
kevsgt
10-09-2015 10:12 PM
KingRando
10-02-2015 08:06 AM
BeatnikFink
10-01-2015 08:00 PM
marc954
09-29-2015 11:18 AM
tj@steeda
Steeda Autosports
09-24-2015 09:18 PM
Quick Reply: 2006 GT axle ratio
