Mustang dies while running no symptoms
Old 06-03-2014, 02:55 PM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm assuming that the TFI tested good, then dig around on the forum for a step by step walk thru on a "no start". If I find it I'll post the link. It walks you thru on diagnosing your problem is. It helped me a couple times.
Old 06-03-2014, 02:59 PM
88 orangepeel notch
Found it
http://sbftech.com/index.php/topic,5...1.html#msg6501
Old 06-08-2014, 08:00 PM
jcgarcia8318
jcgarcia8318's Avatar
Still no go will drive for about 20 30 min then it just kills over
jcgarcia8318 is offline
Old 06-09-2014, 09:47 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
by the time you take a tfi off, bring it to the parts store for testing, it'll cool down and of course test good.......other possible things = stator in the dizzy
mjr46 is offline
Old 06-09-2014, 09:55 AM
88 orangepeel notch
Did you get the TFI tested ? Like mjr said a cold one may test good, Have them run the test 3 times, in a row. It'll be very hot by the end of the third test. That's where a bad one will fail.
Old 06-10-2014, 07:40 AM
jcgarcia8318
I'll let you guys know the status of the tdi on Sunday. But if there's any more ideas I'll be glad to try them out.
Old 06-10-2014, 08:14 AM
88 orangepeel notch
Just out of curiosity, when the car dies, feel your fuel pump relay. Let me know if its hot. It might not be nothing but my car happened to just die on the road at speed this week, only for a second or two, then start back up by itself and motor on like nothing happened. When I got home, I pulled my ECM and harness out of the kick panel while the car was running and it hiccuped again. So I thought lose wire but I couldn't get it to do it again no matter how hard I pulled on the wires, lol. But I did notice my fuel pump relay was very warm to the touch. I also was almost on empty so I filled the tank and the relay stayed much cooler. Maybe my fuel pump got hot, I don't know as I'm still tinkering, but just an idea.
Old 06-11-2014, 12:41 AM
Wrenchman1
Wrenchman1's Avatar
Default resistance
You stated that you pulled the coil wire and got the spark going again? 1st check the engine ground. Don't just look at it , clean it. 2nd I had an engine that would run with a spark tester in line with the coil but not direct. The coil wire was bad. as had a poor ground also. Just a thought
Wrenchman1 is offline
Old 06-11-2014, 05:45 PM
  #19
mongolchuck
mongolchuck's Avatar
Msd boxes and coils do this occasionally, seemingly more often than stock. I'd throw the stock ignition components back on and see what happens.
mongolchuck is offline
Old 06-12-2014, 07:14 AM
  #20
Wrenchman1
Wrenchman1's Avatar
Talking Aftermarket
OEM if ya can, I was wondering who makes FRPP ignition box and coil.
I have an MSD on the 5.0 , That's the way it came TBH, I don't trust em.
Open it up and look at the components, JMHO.
Trying to find out if the FRPP unit is any better.
Im sure the Race teams get stuff ya cant buy.
Random Thoughts.
I have had a lot of issues over the years with aftermarket, Wires, HEI Modules
Crappy points and condensors. Ya Im that Old!
Quick Reply: Mustang dies while running no symptoms
