Hesitating to start
Old 06-06-2014, 08:55 PM
cema93
cema93's Avatar
Default Hesitating to start
Alright every now and then (3-4 weeks) ill hope in my car and drive somewhere. never more than 10 miles. park it. go into watever building i am going into and come back out and try and start the car. The times this has happened the car has sat for 15-40 min. So i hop in the car, turn the key, and i know it primes the lines, i hear it and we have directly wired the fuel pump ourselves, (brand new pump). and when i turn the key, the starter just goes and goes but the car takes a good 3 seconds of turning over to start. its the weirdest thing. then i may go down the street get out, go get a hamburger and come out and it may not do it. it did it the weekend before memorial day after it was hot, then sat for ~20 min. then tonight after sitting for ~30 min. any guesses on what would cause it to hesitate to start? is the engine mods??
cema93 is offline
Old 06-09-2014, 09:50 AM
cema93
cema93's Avatar
anybody?
cema93 is offline
Old 06-09-2014, 12:44 PM
moosestang
moosestang's Avatar
My wifes Chrysler does that and from googling it, it appears to have something to do with the purge solenoid on her car.
If you have a scan gauge that will read fuel pressure, make sure it doesn't drop to zero after the pump primes. It should stay at 40. Mine slowly bleeds down at about 1psi per 5-10 seconds.
You could have leaky injectors
moosestang is offline
Old 06-09-2014, 03:24 PM
cema93
cema93's Avatar
moosestang that makes plenty of sense but why doesnt it do this when the car has been sitting for 1,2,3 or more hours?
cema93 is offline
Old 06-10-2014, 02:54 PM
moosestang
moosestang's Avatar
If it's leaky injectors, the fuel will eventually evaporate, so after a few hours it won't be flooded. Try starting the car with the gas pedal to the floor next time. doing that should stop fuel injection at start up, so if you have fuel all ready in the cylinders, it will start, if the inectors aren't leaking then it won't. It's possible they don't leak every single time you shut off the car.
My wifes car will sometimes do it from a cold start too, which really makes it hard to diagnose. Mostly it's a hot start problem though.
Old 06-10-2014, 06:05 PM
cema93
cema93's Avatar
That was a bit harder to follow. Are u saying that my injectors leak and drip into the cylinders sometimes and when i try and start the car THOSE TIMES, that the cylinders are "flooded" which causes it to just turn over and over for 3-4 seconds?
cema93 is offline
Old 06-10-2014, 06:36 PM
moosestang
moosestang's Avatar
Yes, you could have too much fuel and not enough air = no combustion.
Old 06-10-2014, 06:51 PM
cema93
cema93's Avatar
where does that extra fuel go?
cema93 is offline
Old 06-10-2014, 07:05 PM
moosestang
moosestang's Avatar
Out the exhaust when cranking or into the oil if it sits long enough and doesn't evaporate fast enough.
Old 06-10-2014, 07:18 PM
cema93
cema93's Avatar
hm alright. well thanks a lot for your help.
cema93 is offline
Quick Reply: Hesitating to start
