fluctuating idle speed
Old 06-11-2014, 07:28 PM
col2560
col2560's Avatar
Default fluctuating idle speed
the other day driving home, everytime I pushed the clutch in to change gear, the engine would rev to 1500 rpm. also if just coasting down hill in neutral, the engine stays at 1500 rpm. this means that there is no compression braking. seems to happen more when its wet / raining.
any ideas plz,
thanks.
col2560 is offline
Old 06-12-2014, 07:11 PM
98 svt
98 svt's Avatar
I had it also, changed the idle air control and it got a lot better. It will still stick at 1100 rpm sometimes but doesn't bother me anymore.
98 svt is offline
Old 06-13-2014, 12:22 PM
bdraisey
bdraisey's Avatar
How do you know when you need to adjust the idle?
bdraisey is offline
Old 06-18-2014, 08:04 PM
col2560
col2560's Avatar
ok, I took it off and cleaned it, seems to have fixed the problem, thanks guys !!!
col2560 is offline
Old 06-23-2014, 06:20 AM
98 svt
98 svt's Avatar
Awsome!
98 svt is offline
Old 07-02-2014, 03:56 PM
jas451
jas451's Avatar
My '05 will die when I come to a stop and at times the idle will fluctuate, drop to about 500 rpm and then die. Sometimes it will be fine but will die on me at least once or twice when I have it out. I've cleaned the MAF, the throttle body, the filter (I have a CAI and
brenspeed tunes) had the fuel filter changed, and run fuel injector cleaner. I guess about the only thing left is the fuel pump???
jas451 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: fluctuating idle speed
