GEAR question For GEARHEADS!!!!
Old 06-12-2014, 09:33 AM
87droptop
87droptop's Avatar
Default GEAR question For GEARHEADS!!!!
Hello have a 87 GT. Need to change the gears every since i changed my throttlebody. Whats are the recommended gears for a fox body.
87 GT
longtube header
Msds
70 mm throttlebody
alumium radiator
short throw shifter
Sr intake
87droptop is offline
Old 06-12-2014, 09:51 AM
Boss_Hotrod
Boss_Hotrod's Avatar
Depends on the tranny. Most with T5s go 3.73. with AOD go 4.10. You can also put a 4.10 into a stick car but 1st becomes almost useless.
Boss_Hotrod is offline
Old 06-12-2014, 10:10 AM
As mentioned, above for street use the 3.73 gears are great for the 5 speed manual and 4.10 are better for an AOD auto .
The auto trans is a slush box and the 4.10s really wake it up.
If your planning on the 1/4 mile speedway and you have some good gripping tires the 4.10s on a manual are ok. Other wise you just spin tires.
Some guys find tire smoking impressive, but I find it gets expensive and Im more impressed with using the power to push you down the strip.
Old 06-12-2014, 10:46 AM
87droptop
87droptop's Avatar
87 GT
longtube header
Msds
70 mm throttlebody
alumium radiator
short throw shifter
Sr intake
I dont wanna spin alot but i have nitto performance tires so once they heat up there not a good chance at spinning. I just want solid all around good gears. Its not a daily driver.
Old 06-12-2014, 11:39 AM
AMAlexLazarus
Former Sponsor
AMAlexLazarus's Avatar
87 GT
longtube header
Msds
70 mm throttlebody
alumium radiator
short throw shifter
Sr intake
OP
That's a good one and like dawson1112 and Boss are saying going with 4.10's will make your 1st non-existent Ford Racing's 3.73's are more than enough to wake the car up! I'm not sure if you're a T5 or AOD but be sure to check out the Speedo gears as well (<-Just for example) as your speedo will be off (I never swapped mine in the past but it's a good idea to do so)
-Alex
AMAlexLazarus is offline
Old 06-12-2014, 12:29 PM
azdevil1
azdevil1's Avatar
3 places to get the same gears cheaper than AM....
http://www.dallasmustang.com/gears-r...FQqFfgodxjYALQ
http://www.butler-macmaster.com/m-42...FUOSfgodb2kA7Q
http://www.summitracing.com/parts/fm...FQ-CfgodGGwAkQ
I had 4:10s in my 08 GT vert - def woke it up and I loved it.
Gas mileage - not so much, could have used a 6th gear there.
azdevil1 is offline
Old 06-12-2014, 02:12 PM
88 orangepeel notch
88 orangepeel notch's Avatar
I'm late to this party again. Another gear thread lol.
I love my 3:55s, but since your alittle closer to stock power, I agree with everyone above. T5 = 3:73 ………AOD = 4:10.………… gears = happiness.
Old 06-12-2014, 08:02 PM
barnett468
barnett468's Avatar
depends if you want mainly street, fwy or inbetweem
3.50 is decent for street but great for high fwy speeds.
3.73 is inbetween,
3,91 on up is mainly street.
4.10 with an aod is street mainly. it is NOT an all around gear by any means.
3rd in an aod is the same ratio as 4th in a 5 speed.
barnett468 is offline
Old 06-12-2014, 08:13 PM
Wrenchman1
Wrenchman1's Avatar
Default Final ratio
5spd, 6spd and AOD are all close in final drive ratio. .62 to .82 I belive.
You can pop your numbers into a virtual dyno and see where your at!
Ah its just fun! Watch the heat you can cook your
cool juice( anti freeze) and over heat
Wrenchman1 is offline
Old 06-13-2014, 09:08 AM
AMAlexLazarus
Former Sponsor
Hey AzDevil1,
Thanks for bringing this up!!!
We price match here at AmericanMuscle- So if you're to ever see something listed elsewhere for less shoot us a call and we'll have a match setup. I'll be sure to have this forwarded over to the appropriate team right now so we can have that sorted.
Thanks Again!
-Alex
Luke9222
10-22-2015 11:55 PM
musnicki
09-23-2015 07:11 AM
Mustangmalo
09-06-2015 05:22 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: GEAR question For GEARHEADS!!!!
