Detonation
Old 06-17-2014, 04:10 PM
Evan02
Evan02's Avatar
Default Detonation
I've been getting detonation sounds for a while now. It began when I wrote one of those custom Bama tunes from AM. I would get A LOT of detonation sounds when in fifth gear constantly.
I took the tune of and went back to the stock tune, every once in a while I will still hear it (not nearly as loud). I don't know if the bama tune caused this to happen or its always been happening and I never noticed until the tune magnified it.
The problem is I don't know what's causing it. The guys at Bama told me I should change out my spark plugs, fuel and air filters, which I did, but the problem is still there. They said that they shouldn't have to retard the timing on the tunes.
But I feel the problem is deeper than plugs or filters. Any ideas?
Evan02 is offline
Old 06-17-2014, 05:33 PM
CalBoy101
CalBoy101's Avatar
Running too lean can give you detonation problems.
You could have dirty injectors or a fuel pressure issue.
If the injectors have more than 30,000 miles or so I'd get them cleaned and flowed. I use an online company at www.mrinjector.us for this, they come back looking like brand new with a flow sheet showing the before and after flows.
If you have a hand held tuner for your Bama tune you should be able to data log.
I'd log the fuel pressure drop across the injectors and fuel pump duty cycle to makes sure you don't have a fuel supply problem.
CalBoy101 is offline
Old 06-17-2014, 06:03 PM
A build up of carbon on a valves or pistons can cause detonation also. The carbons gets red hot and ignites the fuel mix early.
Old 06-17-2014, 06:52 PM
Evan02
Evan02's Avatar
The injectors do most likely have more than 30,000. They probably have about 85k on them I don't think they've ever been changed, I got the car last summer.
While I would like to send them out I can't. It's my only car, I wouldn't be able to get around.
The guys at BAMA also told me to try running sea foam through it. Is it worth a shot?
Evan02 is offline
Old 06-17-2014, 07:09 PM
CalBoy101
CalBoy101's Avatar
You might be able to find a local place to do the cleaning.
Also if you have a compressed air source its not that hard to hack up your own home brew injector cleaner. Basically you just need to put some voltage on the injector to switch it open and closed.
An old D cell flashlight housing works for this, run wires from the bulb connections to the injector pins and use the flashlight switch to open and close the injector.
Get a long piece of tubing that fits on top of the injectors, fill it with carb cleaner, connect compressed air to the top of it and use the flashlight switch to open and close the injector.
There are youtube examples of doing this, search "home made fuel injector cleaner" and you'll hit them.
Don't use a flammable solvent for this though, it might go boom.
I didn't answer your post just to try to sell you some injectors but I do have a set of pink 21# injectors that were cleaned and flowed by www.mrinjector.us .
They ran great on my 02 GT when it just had bolt ons and I also had a Bama tune. I put only around 1000 miles on them and then switched to a KB with bigger injectors.
The pink 21's came on 02-04 GT's but can be swapped in to the 99-01's without needing a re-tune.
I'll let them go for $110. including shipping, they come with the test flow sheet from mrinjector.
Send me a PM if you are interested in them.
All that said, the detonation you are getting could be dirty injectors but like Dawson said it also could be carbon build up or something else.
Take a look at your plugs and see if they have black deposits on them.
Old 06-17-2014, 07:14 PM
Evan02
Evan02's Avatar
I'll definitely have to give this a try ASAP
Evan02 is offline
Old 06-24-2014, 09:21 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
This could be a few different things. It sounds like you've already replaced a lot of the "go to" problems for detonation. If the car is detonating with and without the Bama tune, it's clearly not related the tune. However, we can definitely help you troubleshoot.
You can feel free to give the Bama team a call and they'll gladly work with you! Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
-Dan
AMDanBailer is offline
Old 07-02-2014, 05:56 PM
Evan02
Evan02's Avatar
Well, I tried running seafoam through the fuel system too.
The pinging only seems to be occurring with the tune now.
Evan02 is offline
jwog666
12-27-2021 08:09 PM
spectreman
03-31-2016 09:26 PM
wildazme
03-23-2006 09:12 PM
91stang331
06-08-2005 12:31 AM
jishead
02-15-2005 08:11 PM
Quick Reply: Detonation
