2002 engine rebuild
Old 06-19-2014, 06:08 PM
VTX1800N1
VTX1800N1's Avatar
....and the power just went out as I was about to go out in the garage and sweep up the kitty litter to finish this up. It's too hot out to open the garage door. Hasn't been my day today.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 06-19-2014, 08:24 PM
Hangwire
Hangwire's Avatar
Yep this is a cool father/son deal. My pops never woulda done this with me.
Another thing I like is that your properly listing a true complete list of parts/prices. People always under quote or under estimate stuff like this and it leads to bad conventional wisdom like supercharger kits can be setup for $1500.
And yes if you have ogre hands the passenger side is a real hassle. Thankfully when I have worked on that stuff a combination of proper sockets gets me to the bolts. And with a scratched up arm and some wiggling I could just barely reach the o2 sensor.
The single hardest thing i've ever had to remove was a bracket on the rear of the engine block behind the drivers cylinder head. I had to remove it for the KB install and I forgot why. It literally wasnt even attached to anything else. It must have been something as a result of the modular windsor/romeo nature of these motors. It was meant for something.....just not on my car. I think i've still got it as a token of frustration.
Hangwire is offline
Old 06-19-2014, 08:56 PM
VTX1800N1
VTX1800N1's Avatar
Driver side exhaust, easy:
Passenger side exhaust, not so easy:
Removed the starter and K-member brace, and success:
The starter did have three bolts, but only two were installed. Obviously someone removed it in its 143K mile life and didn't put the most difficult bolt back in. I'll have to source another as it's not good for the starter or flywheel to be missing that bolt. Reinstalling the starter is going to be the biggest pain of the engine installation by far.
Old 06-20-2014, 12:06 AM
VTX1800N1
VTX1800N1's Avatar
Clutch cable, driveshaft, A/C, and power steering pump removed. Should be ready to pull the motor tomorrow.
Old 06-20-2014, 04:04 PM
WJL
WJL's Avatar
By looking at the last pic your car is an automatic, want to know how i know? I just finished put the bottom end in mine engine is back in the car just haven't had the time to finish up. will post some pics once i figure out how to do it
WJL is offline
Old 06-20-2014, 04:29 PM
VTX1800N1
VTX1800N1's Avatar
Um, actually, no. It's got the Tremec 5 speed manual, hence the mention of a clutch cable in my previous post....
Old 06-20-2014, 08:43 PM
WJL
WJL's Avatar
In the last picture you can see a webb in the corner of the engine block, according to Ford this type block was only used with an automatic Could be wrong
WJL is offline
Old 06-20-2014, 09:23 PM
VTX1800N1
VTX1800N1's Avatar
The blocks are the same for either manual or automatic. I have no idea where you got that info, but it is not correct.
Old 06-21-2014, 02:01 AM
  #19
Hangwire
Hangwire's Avatar
I have never heard of Ford having engine block webbing differences between the autos and manuals for 99-04 Mustangs. The only thing that dictates the differences between any of the 99-04 engine blocks was what year and ford plant it was built at(Windsor/Romeo). And even there are minimal differences. Most have to do with the cylinder heads/timing sets and how they attach.
Hangwire is offline
Old 06-21-2014, 03:23 AM
  #20
JC316
JC316's Avatar
Oh yeah, that passenger side exhaust always sucks. I always leave that top starter bolt out. Never had a problem. If it were shimmed like the SBC starters, it would be necessary, but I see absolutely no benefit to it being there.
JC316 is offline
Quick Reply: 2002 engine rebuild
