2002 engine rebuild
Old 06-21-2014, 06:13 AM
  #21
WJL
WJL's Avatar
Ok whatever you say.
WJL is offline
Old 06-21-2014, 07:27 AM
  #22
VTX1800N1
VTX1800N1's Avatar
Originally Posted by Hangwire
I have never heard of Ford having engine block webbing differences between the autos and manuals for 99-04 Mustangs. The only thing that dictates the differences between any of the 99-04 engine blocks was what year and ford plant it was built at(Windsor/Romeo). And even there are minimal differences. Most have to do with the cylinder heads/timing sets and how they attach.
Crankshafts are different too. Windsor is 8 bolt and Romeo is 6 bolt in most cases, IIRC. That also means different flywheel or flex plate for manual/automatic.
Sent from my XT1080 using IB AutoGroup
VTX1800N1 is offline
Old 06-22-2014, 05:44 PM
  #23
VTX1800N1
VTX1800N1's Avatar
Default Motor is out
Old 06-22-2014, 07:13 PM
  #24
CalBoy101
CalBoy101's Avatar
Originally Posted by JC316
Oh yeah, that passenger side exhaust always sucks. I always leave that top starter bolt out. Never had a problem. If it were shimmed like the SBC starters, it would be necessary, but I see absolutely no benefit to it being there.
I tried to convince myself that it was ok to leave the top starter bolt out until I got a close look at the bolt bosses on the trans that those bolts go in to.
There's not much meat there and its aluminum at that so I had to put that top bolt back in to be able to sleep at nights.
Getting to these bolts isn't too bad if you using a 24" extension from the front with a universal joint on it, but this was on lift with another pair of hands to get the socket set on the bolt head.
CalBoy101 is offline
Old 06-22-2014, 09:02 PM
  #25
VTX1800N1
VTX1800N1's Avatar
Default And now we see why cylinders 3 & 4 weren't firing...
Old 06-22-2014, 09:04 PM
  #26
VTX1800N1
VTX1800N1's Avatar
There were seven bolts on the passenger side cam retainer bosses that were finger tight or less. The bosses flexed and all four rockers for cylinders 3 & 4 fell out. I thought by the compression test and misfire codes that the lifters had collapsed. Turns out it was even worse than that.
Old 06-23-2014, 06:56 PM
  #27
VTX1800N1
VTX1800N1's Avatar
I was surprised to see cast iron, ratcheting tensioners when I took the timing cover off:
Old 06-23-2014, 08:00 PM
  #28
VTX1800N1
VTX1800N1's Avatar
Thin coat of sludge in the oil pan:
Overall, not too bad for 143K miles:
Old 06-23-2014, 08:13 PM
  #29
VTX1800N1
VTX1800N1's Avatar
Old 06-24-2014, 01:53 AM
  #30
Hangwire
Hangwire's Avatar
Hey man I think you might want to have those things connnected haha.
Thats pretty crazy that the bosses would flex. That is completely abnormal wear/defect. I dont think i've ever heard of bosses flexing and rocker/rollers just falling the hell out. Something along the way caused the bizarre behavior with those lifters/rockers/valves.
I wonder if the worn/cracked component started to let the cam run incorrectly. As small as that difference would be.
This is good stuff. Keep doing work!
Hangwire is offline
Quick Reply: 2002 engine rebuild
