5.0L Stroker Assembly Question
Old 07-03-2014, 02:46 PM
  #21
danzcool
danzcool's Avatar
Originally Posted by gmoran1469
You don't have an aluminum block? Aren't all 05+ GT's aluminum blocks?
The OE equipment on 05-10 were aluminum block, but he has a built block. the cobra block and "boss block" are cast iron 4.6L engines. Since about 2011 if you wanted to start with a brand new block, your only choice was a cast iron 4.6L (unless you bought from a company that had stockpiled new aluminum blocks).
danzcool is offline
Old 07-04-2014, 02:02 PM
  #22
Simon1
Simon1's Avatar
Correct.
There is probably an aftermarket solution to this but the cost would probably be unbelievable. I have considered buying a used long block from someone like LKQ just to have the short block available to me. The bare blocks were going for around $1100 prior to them becoming unavailable.
Simon1 is offline
Old 07-07-2014, 03:13 PM
  #23
gmoran1469
gmoran1469's Avatar
What are people using as their redline RPM with a forged stock stroke vs forge 5.0L stroker? I am at 6500 (motor cuts power after that) right now.
A stock stroke forged motor that revs to 7.5-8k would be sweet.
gmoran1469 is offline
Old 07-07-2014, 08:09 PM
  #24
danzcool
danzcool's Avatar
I use 7K as the redline on mine, it has a mild stroke 4.75L (will soon be 5.15L with a bore on the same stroke). I think the ECU on the 05-10 has a limit of 7500rpm??? But a higher redline is more of a limitation of the valve springs than anything else once your lower end is forged.
danzcool is offline
Old 07-07-2014, 11:25 PM
  #25
Simon1
Simon1's Avatar
With better valve springs, 7,000.
Simon1 is offline
Old 07-08-2014, 08:43 PM
  #26
gmoran1469
gmoran1469's Avatar
Define better. Lighter, stronger? I don't know much about it so. All I see from e-tailers are comp springs except for livernois.
http://www.livernoismotorsports.com/...e-Springs.html
chrisdbassplayer
10-13-2015 06:53 PM
treesloth
09-28-2015 07:03 AM
tj@steeda
09-17-2015 07:32 PM
EASTIDEE123
09-14-2015 03:52 PM
tj@steeda
Steeda Autosports
09-10-2015 08:39 PM
Quick Reply: 5.0L Stroker Assembly Question
