How to wire an wideband air/fuel gauge
Old 06-20-2014, 07:53 AM
yurizx6r
yurizx6r's Avatar
Default How to wire an wideband air/fuel gauge
Hey guys, this is probably a dumb question, but I'm still a noob at wiring. I was wondering how you guys wire up your air/fuel gauges?
This is the meter I have:
http://www.carid.com/auto-meter-cust...-12635162.html
These are my instructions:
http://www.carid.com/images/auto-met...structions.pdf
my question is what sources do you guys plug your red wire into? Mine also did not come with a fuse. Also, where do you plug the white wire into for the dimming function? I am also assuming some of the other wires (black, blue, and brown) I do not need since I have a stock computer and just a bama tuning chip and not an advanced tuning system right?
Thanks for any help in advance!!!
yurizx6r is offline
Old 06-20-2014, 11:40 AM
yurizx6r
yurizx6r's Avatar
All it says is for the red wire is to put it into the ignition switch..............where!? Which wire in the switch!? I'm just really confused with the red and white wire....
yurizx6r is offline
Old 06-20-2014, 02:12 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Look under the dash and find a red/yellow wire. There are tons of them. Those are switch 12v wires. As far as the dimmer goes does the gauge have a bulb or LED. If its an LED find the brown park light wire and tap into it. You can use the warning chime (behind the left side of center console for both of these. If the gauge has a bulb in it and you dont want it to be bright all the time youll have to pull the dimmer out and hit the (I think) blue/red wire. That wire controls the instrument cluster back lights.
Boss_Hotrod is offline
Old 06-20-2014, 02:35 PM
bluebeastsrt
bluebeastsrt's Avatar
Take it to the local shop. Sounds like it would be money well spent!
bluebeastsrt is offline
Old 06-20-2014, 03:40 PM
Maxwelhse
Maxwelhse's Avatar
Especially since a bung is going to need welded in somewhere for the sensor itself.
That said... ya gotta learn somewhere.
Maxwelhse is offline
Old 06-20-2014, 04:33 PM
gmoran1469
gmoran1469's Avatar
I wired up an AFR gauge for my track only rx-7. You'll need to weld the bung in a 9-3 o-clock position for best results, 12 o clock is optimal. put it after the header where the exhaust converges to one point preferably.
The 12v ignition switch will be the 12v that gets passed through the switch when it's in the on position. You can use a meter to find which one has 0v when the ignition is OFF and 12v when it is ON. 12v dash lighting can be hooked up to the 12v switch that gets powered when you turn your headlights on (backside of your headlight switch). You can just splice the wires in with a butt splice or solder and shrink them.
gmoran1469 is offline
Old 06-21-2014, 09:57 PM
yurizx6r
yurizx6r's Avatar
Figured it out. It works perfectly. Took a long time to do everything perfectly, but it's done. White wire to the parking lights, blue is to the computer/tuner system, brown to the positive terminal, 2 black wires to the ground, and the red wire to a line on the ignition switch that gets power once the key is turned. Done.
yurizx6r is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
SteelerNation82
09-16-2015 07:11 AM
Quick Reply: How to wire an wideband air/fuel gauge
