5.0 Oddities
Old 06-22-2014, 02:32 AM
2000AZ5.0GT
2000AZ5.0GT's Avatar
Default 5.0 Oddities
So, I threw out the plan to keep my car stock as can be, and eventually it will be a HCI fox, shooting for around 280hp at the wheels.
So, I'm starting with the supporting stuff first, 130A alternator, 3 core radiator, dual high flow fans (though due to some of the reviews, I might be swapping that out for a high flow 16"), high flow water pump (most likely), and probably some random stuff here and there.
Living in AZ is torturous on cars during the summer, but luckily I have a garage, and a daily driver, so I've been doing most the work during the week, after work and all that jazz.
Now to the Crux. No matter what I do, I cannot get a stock length serpentine belt around the pulleys using the stock routing. Obviously, before I took the belt off it was by definition already running, but having run a wire/tape along the route, I found that what is existing is 95 inches long, quite a bit longer than the 91 and 1/8th inch thats supposed to be there from the factory.
Then, when I took the alternator off, I found that the new 130 amp wouldn't fit, it was literally too short. Turns out the engine had the wrong Alternator/Smog pump bracket.
Thank god it's a mustang, I was able to find a stock bracket online and picked it up today, same day that I noticed, but after installing that, I still can't get the stock serp belt on.
So, to my question, is there a stamp or something I can look for on the block to verify that the engine did in fact come in my car from the factory?
2000AZ5.0GT is offline
Old 06-22-2014, 10:08 AM
Maxwelhse
Maxwelhse's Avatar
A picture can probably help us verify your belt setup faster than anything. You might want to measure the pulley sizes on the accessories too in case some of the mounts are correct but the accessories are not. Same with the crank pulley.
Another thing on my mind is whether or not this is a 3G alt swap. If it is... they don't fit in the stock bracket without modifications. If you got it to fit and didn't grind on anything you probably STILL don't have the right bracket.
Also, with those cooling mods in mind I'd STRONGLY suggest adding a heater core restriction orifice. Probably a good idea to bite the bullet and plan on putting a new core in it anyhow (pain in the *** job) AND an orifice.
Maxwelhse is offline
Old 06-22-2014, 08:47 PM
2000AZ5.0GT
So, from looking into it, I highly suspect that the engine is out of a 88'-92' Lincoln Continental MK VII, the brackets for the AC, power steering, and alternator were identical to pictures I found online of the Lincoln set up, which to me, is even more reason to do a HCI build.
Eventually, I'm going to buy either a reman block or a dart block, and get the correct accessory drive, as I think it would be dishonest to sell the car with the current engine and not disclose such info.
As far as the bracket goes, turns out the guy that had it had already made the modifications for the 3G, so yeah, I didn't need to modify the bracket.
Ended up going with a 94" belt, seems to work okay. Still don't have the fans wired up.
Do you have a link to the restrictor? I don't currently have the heater core connected, I believe it was bypassed a while ago, and I haven't re-connected it.
Here are a few pictures, and a video.
Old 06-22-2014, 11:32 PM
Maxwelhse
Maxwelhse's Avatar
Looked like a Fox setup to me at first and then I finally found it (they're pretty close)! A/C bracket AND P/S bracket aren't Mustang (or at least my year). On a Mustang the PS casting bolts to the A/C bracket. For some reason (that makes me want to slap Ford) they tooled up unqiue brackets for BOTH of those parts for whatever car that motor came from instead of just a new A/C bracket and relocating the holes that P/S casting mounts to. Never mind the fact that your arrangement obviously fits in a Mustang... Stupid engineering...
I've attached some pictures of my FEAD. The before paint picture shows it more easily. Your upper radiator hose is "funky" too and looks kinked? Maybe its just the angle of the picture? I always thought the Lincoln motor was exactly the same. Apparently not! Maybe its not even a Lincoln motor? Does it have an HO firing order (verified at the distributor)?
As far as the restrictor (and if your core is by-passed its leaking... I'd bet money on it) I made mine out of a 2" slug of 304 stainless round bar (can't remember the exact size.. 3/4", 5/8"?) and drilled a 5/16" hole through the middle of it. It installs on the inlet side of the core. The 5/16" hole is just fine for summer driving when you get some haze on the windshield at night, but here in the midwest you'll barely have enough heat in the winter to keep the windshield clear in 30F temps and will freeze your *** off (based on my experience with the *1* time I winter drove my car when I moved and 30F here in the winter is actually pretty warm). You shouldn't have a problem out in the desert though!
You can buy a plastic/rubber one here for $20:
http://www.latemodelrestoration.com/...low-Restrictor
A drill bit and SS bar stock is cheaper and isn't going to fall apart any time soon!
Old 06-23-2014, 10:33 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the mark 7 motor is exactly the same internally as the mustang 5.0ho.
the heater core is a job if you need it done. it will take all day and you can do a fast freddy way(that way you dont need to tear into the ac system) you make a small cut on the heater case and pull the core out. if you do put a new core in only buy a motorcraft core and run the restrictor and test it for pressure before installing it.
rmodel65 is offline
Old 06-24-2014, 01:33 PM
Maxwelhse
Maxwelhse's Avatar
Good advice. I put a Robinair unit in mine though as I've had good luck with their parts in the past (FoMoCo doesn't "make" the core anyhow) and it was a good quality.
The heater core job sucks big time... I wouldn't call the "fast freddy" way "fast". That's how I did mine and if I had entire chunk of time to work on it I would say it would have taken me 2 full days. At least there are LOADS of good write ups about it.
Old 06-24-2014, 03:02 PM
2000AZ5.0GT
To be honest, in AZ, I doubt I'd ever need to actually run the heater, I don't recall ever using it in any of the cars I've owned. I know it can function like an additional radiator by running the A/C on hot, but hopefully the $600 dollars I've spent on the radiator/fan set up will keep the car running cool.
Also, this is a garaged baby,she's never going to be out in bad weather as long as I own her.
And I assumed the internals between the Lincoln Engine and mustang engine were the same, the only issue is that it leaves me in the dark as far as the true mileage on the engine. I know the body only has 9x,000 miles on it, but the engine has some unknown number.
Kind of a perfect excuse to throw a turbo on it, or throw a HCI and not care, since it's not my daily driver, I'm going to have to throw a new engine in at some point if I ever plan on selling, so might as well have extra fun in the meantime.
Old 06-24-2014, 06:45 PM
Maxwelhse
Maxwelhse's Avatar
Mine is a fair weather toy too (also garaged) but I don't treat it like a rare jewel or anything. I drive it to work or out and about sometimes and if it rains and gets muggy the heated defrost is nice (probably not much of an issue in AZ either). For me, the fact that it should work and doesn't would drive me nuts. The concept of cooling the car with the heater core is with the HEAT on, not the AC (that will actually make things worse). It doesn't do all that much anyhow.
I'm still curious to know if your motor is running an HO firing order. That would pretty much close the book on it being a Mark VII motor as far as I would be concerned. I personally wouldn't care about it having a Lincoln motor but I'd probably wrap Mustang brackets on it to make life easier (so anyone can put a belt on it at any time).
Old 06-24-2014, 09:47 PM
2000AZ5.0GT
It doesn't have the HO firing order, I don't think. Does that imply that it is from a Lincoln? Or not? Cause the Lincoln's look like they have the HO firing order.
Old 06-24-2014, 09:50 PM
Maxwelhse
Maxwelhse's Avatar
That implies that it is NOT from a Lincoln and not an HO motor. Could be a truck engine or something.
Quick Reply: 5.0 Oddities
