High Rev When Coasting InNeutral
Old 06-22-2014, 06:10 PM
zexus
zexus's Avatar
Default High Rev When Coasting InNeutral
I have a manual 2014 Mustang 3.7 with the performance package 3.31 gears. The car is 2 weeks old and over the past two weeks Ive noticed 4 times that when I am driving and put the car in neutral when coasting to a stop the revs jump up to between 2550 and 3500 rpm for about 2 or 3 seconds and then come down. it does not happen all the time and it has happened at different speeds and gears. I read about this issue on older Mustangs but could not find anything like this on newer ones. In fact there was a recall for this issue on 2006's. Anyone have or had this problem on newer Mustang? Thoughts?
Thanks.
zexus is offline
Old 06-22-2014, 10:03 PM
cruisin5268d
cruisin5268d's Avatar
Get to know the forums to see if others that have the 5.0 are having similar issues. That revving seems to be higher than what I have seen on my 2010 and read about others with the 5.0.
Since it is brand new, why aren't you taking it to the dealership with your concerns? If there is something wrong, you aren't helping things by driving around.
cruisin5268d is offline
Old 06-22-2014, 10:46 PM
steel pony
steel pony's Avatar
Thanks.
Totally different engine...
as the last poster said...if it's a concern, then take it to the dealership since it's still under warranty
steel pony is offline
Old 06-23-2014, 03:30 PM
zexus
zexus's Avatar
Already have an appointment with the dealership. Just thought I'd check here to see if this was a common issue or not...I guess not.
zexus is offline
Old 06-24-2014, 12:13 PM
FordServiceCA
Official Ford Rep
FordServiceCA's Avatar
Welcome to the forum, zexus! I'm Brittany, the Ford Canada Customer Service Rep. It's a pleasure to meet you!
I'm here to help. Have you already brought your Mustang to the dealer for diagnosis? Please send me a quick status update via private message along with your full name, VIN, dealer information, updated odometer reading, and best daytime contact number. Once I receive the PM, I will look into it.
Brittany
FordServiceCA is offline
Old 06-26-2014, 08:34 PM
zexus
zexus's Avatar
Thanks. I will let you know once the dealer diagnoses the issue.
zexus is offline
CS2007
06-25-2019 09:45 PM
firehorse02
11-16-2015 11:28 AM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: High Rev When Coasting InNeutral
