Comp 127500 idle video
Old 06-22-2014, 06:22 PM
2005Redfire6
2005Redfire6's Avatar
Default Comp 127500 idle video
Hey guys, just wanted to share an idle video I had of my Comp 127500 cams, idle set at 800.
Livernois 298 stroker, Comp 127500 cams, BBK Long tubes, O/R X-Pipe, and Pype bombs.
2005Redfire6 is offline
Old 06-22-2014, 10:42 PM
steel pony
steel pony's Avatar
There's just something sexy about a cammed 4.6L
Well done!
steel pony is offline
Old 06-23-2014, 09:28 AM
Mellowdien
Mellowdien's Avatar
Awesome! you posted a dynosheet not too long ago right?
We're the cams already in when you did?
127500? are those SPR cams?
Mellowdien is offline
Old 06-23-2014, 11:20 AM
2005Redfire6
Yes they are with SPR. The dyno sheet was with the cams, they are locked out though. Ideally would have been better with lighter valve springs and limiters instead of lockouts... You live and learn.
Old 06-25-2014, 06:01 PM
Callinectes
Callinectes's Avatar
That's my new favorite song.
Callinectes is offline
Old 06-26-2014, 05:49 AM
Scott2
Scott2's Avatar
Sounds very healthy!
I used 127550 cams in my SC build. Just so you know, I started out with FRPP Limiters but had some valvetrain/phaser noise at start up. Under investigation the little limiter spring in the passenger phaser was broken. While I am sure this did not cause the noise when I put the motor back together I used Livernois Lockouts and no more noise. Go figure!
Scott2 is offline
Old 06-27-2014, 02:21 PM
2005Redfire6
Lol, mine too!
Yeah thats also part of the reason why I did lockouts, didn't want to have issues with the limiters.
Old 06-30-2014, 09:25 AM
kevinmalec
kevinmalec's Avatar
Sounds beastly, Eddie!
kevinmalec is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
tj@steeda
Florida Regional Chapter
09-30-2015 08:04 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Comp 127500 idle video
