Speaker Upgrade from Stock - Help needed
Old 06-22-2014, 07:25 PM
JTFS
JTFS's Avatar
Default Speaker Upgrade from Stock - Help needed
I have a 93 LX with a stock "Premium Sound System" with some type of amp under the passenger seat. The stereo is a simple unit and I am sure the speakers are not so great either. If I was to keep the stock stereo, (Only due to I want to keep the original look) What speakers would be a good choice. I figure I would like to stay under $100.00 for the rear pair which are 5 x7's. I also have speakers in the door and dash. Any help would be appreciated.
JTFS is offline
Old 06-23-2014, 01:51 AM
Maxwelhse
Maxwelhse's Avatar
You're going to be pretty limited by your budget and goal of maintaining the factory source unit. I would suggest that you go down to the store and try out a few speakers to see what you like best. If your factory speakers are functioning in reasonable condition today you probably won't notice much difference at all except the rear possibly being louder due to more efficient, or lower resistance, speakers. That's pretty much the opposite of what you want since humans are designed to listen from the front.
The single biggest thing you can do to improve the sound quality for as little money as possible is change the source unit out. Even the lowest cost dirt simple Pioneer will be a HUGE improvement over a stock '90s Ford unit.
Whatever you do please buy the wire harness adapters so you don't cut up the factory wiring. You can always go back easily later that way and it's only original once.
Maxwelhse is offline
Urambo Tauro
12-17-2016 03:30 PM
squishbang
01-26-2016 04:58 PM
69FB
08-18-2015 08:50 PM
jdphillips73
08-16-2015 04:34 PM
defarmer
08-13-2015 06:40 AM
Quick Reply: Speaker Upgrade from Stock - Help needed
