TRANSMISSION ISSUE!
Old 06-23-2014, 01:14 AM
boski032
boski032's Avatar
Default TRANSMISSION ISSUE!
Just all of a sudden my automatic stock trans in drive is now barley shifting second gear is short 3rd gear is very lagy and when 4th hit I max at 40 an it seems like it slips into neutral.
In overdrive it actually goes above 40 but 3rd is real laggy going in and also 2nd is short. Another odd thing is thay my throttle pedal is now feeling way lighter then b4 when pressing down. Id appreciate the help thanks!!
boski032 is offline
Old 06-23-2014, 04:27 AM
Check your TV kick down cable and make sure it is not broken, loose or disconnected , check at the throttle body and at the trans. Driving around with a broken or other wise misadjusted TV cable will destroy your trans in short order.
Old 06-23-2014, 09:15 AM
88 orangepeel notch
88 orangepeel notch's Avatar
+1 ^^^
But what are you doing in this forum dawson, shouldn't you hanging around with your new friends, with your fancy new car lol.
I tease cause I love.
Old 06-23-2014, 01:04 PM
boski032
boski032's Avatar
Alright I'll check that. The cars only got 33,000 miless on it
boski032 is offline
Old 06-23-2014, 01:57 PM
88 orangepeel notch
That is really low miles, but the plastic clips that hold these cables on get brittle with age and can crack/break very easily.
Check the operation of the TV cable when you find it. Make sure the cable operates freely. It's odd that you said you felt the gas pedal get easier. Meaning the TV cable may have corrosion in it. The cable should move freely in the protective sheath.
Old 06-23-2014, 02:13 PM
Originally Posted by 88 orangepeel notch
+1 ^^^
I don't have any friends lol.
mtgldr
02-03-2024 09:00 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
04stangman
09-26-2015 09:33 AM
LivingInThePast
09-16-2015 12:20 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: TRANSMISSION ISSUE!
