91 5.0 gt
Old 06-24-2014, 09:18 PM
Bailey1$
Bailey1$'s Avatar
Default 91 5.0 gt
91 5.0 mustang gt
Ok I am wanting to put these gt40 heads and intake on my car. I have a 75mm throttle body
And spacer. Also thinking ab buying new fuel rails with 24 lb injectors. And 75mm MAF housing with sensor. Will I have to do anything to this computer?
Also any info will be greatly appreciated.???
Bailey1$ is offline
Old 06-24-2014, 09:53 PM
Maxwelhse
Maxwelhse's Avatar
Not if the MAF is a "calibrated" unit for 24lb injectors.
The rails are a huge waste of money for your setup IMO.
Maxwelhse is offline
Old 06-24-2014, 11:52 PM
Bailey1$
Bailey1$'s Avatar
Thank you!ready for the weekend to get started
Bailey1$ is offline
Old 06-25-2014, 09:54 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Also, the 19's will be fine for your mods if you want to save the money for something else.
Old 06-25-2014, 10:14 AM
Max_Apex
Max_Apex's Avatar
Unless you're going to supercharge or turbo the motor, the injectors and tb are wayyyy over kill. Your stock 19lb injectors are good for 300-350 hp set up. With the heads and intake, you won't be anywhere near 300. Also, 65mm tb is more than enough too.
I have a 91 vert 5.0, and I'm rockin gt40 heads and intake, e303 cam, 65mm tb, cai, shorty bbk headers, bbk x w/highflow cats, and slp lm1 cat backs. I haven't dyno'd the car but I know the setup is still sub 300hp.
Max_Apex is offline
Old 06-25-2014, 10:36 AM
Bailey1$
Bailey1$'s Avatar
Well that's a bumer done bought the parts lol
What else can I do to pick up more power ?
Don't money for turbo or super charge nor
The how to lol. Car has under drive pulleys
Headers x pipe with flows msd coil. Racing
Fuel pump. After I get these heads an intake
On I'm goin to put 3.73 gears in it. ???
Also which would be easier on labor turbo
Or super charger? And cheaper to do?
Bailey1$ is offline
Old 06-25-2014, 01:15 PM
Bailey1$
Bailey1$'s Avatar
Also what heads would y'all suggest with my setup
And the price? The gt. 40 heads I have are not on yet.
Was goin to have them port an polished /dipped with
Trick flow spring?
Bailey1$ is offline
Old 06-25-2014, 01:58 PM
88 orangepeel notch
I'd do the gears first as that's by far the best bang for the buck you can do for these cars. Then decide on what you want out of your car, daily driver, track only, etc etc. Then set a limit on funds, and start researching pros and cons of the mods your looking at.
Use the search feature here and you'll be reading for days.
Old 06-25-2014, 04:17 PM
Maxwelhse
Maxwelhse's Avatar
I would skip the porting work on the GT40s unless you can do it yourself. Its just not a very good financial investment. I say that as a guy that had his ported and put on the flow bench. Run the springs your cam recommends.
Like '88 said, figure out what you want to do with the car. Some of the best money I've spent on mine, as just a fun street car on a budget, is FRPP B springs. If I was going to drag all the time I'd probably have went with stock 4 cylinder springs. BOTH are cheap options.
Old 06-26-2014, 08:41 AM
Max_Apex
Max_Apex's Avatar
Yeah, 373 gears will make a big differance on the ol' butt dyno. Makes the car really wake up. The last few guys that posted really had good advice. Its all about what you want to do with your ride.
I will say, with the tb, injectors, and fuel pump you have, I'd save the dough for a twisted wedge hci package. If memory serves me correct, the "street burner" package is good for 350+ish hp. Maybe look into that.
Max_Apex is offline
Granatelli Sales
03-25-2016 08:01 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 91 5.0 gt
