low idle on start up - sputtering once driving
Old 06-28-2014, 12:57 PM
TOOT
TOOT's Avatar
Default low idle on start up - sputtering once driving
When I start the car up 1st thing in the morning or after it has sat for more than a 6 or so hrs I have a hard time keeping a decent idle. I start it and give it a super fast light tap on the gas to keep it running( multiple times) is the only way to keep it from shutting down. I leave for work around 5am so I'm conscience of disturbing the neighbors with multiple starts.
Once she does start and I'm driving it it sounds like a VW Beetle's exhaust (old school VW Beetle) with a slight sputter all through 1 gear, I 1st thought it was from a exhaust leak but since that was fixed it's still doing it.
Both issues are only when the engine is cold 1st start of the day, once I'm at work for a couple of hrs then leave and drive it's fine no starting issues and no sputtering.
Thanks on advance.
TOOT is offline
Old 06-28-2014, 01:35 PM
bluebeastsrt
bluebeastsrt's Avatar
Tune up?????? Ever change the distributor cap?
bluebeastsrt is offline
Old 06-28-2014, 05:09 PM
TOOT
TOOT's Avatar
No I've owned it just over a year, I'll start gathering parts for a complete tune up.
TOOT is offline
Old 06-30-2014, 10:24 AM
88 orangepeel notch
88 orangepeel notch's Avatar
That's where I'd start also, then pull codes just to see if you have a sensor or switch that's not reading right. ECT sensor ???
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
MEISTERSNFB
03-31-2020 07:50 AM
drfister
05-03-2018 10:38 PM
fdnyems19
08-13-2015 09:36 AM
Quick Reply: low idle on start up - sputtering once driving
