Rebuild or sell?
Old 06-29-2014, 09:05 AM
import slayer
import slayer's Avatar
Default Rebuild or sell?
Last night I took my '82GT to the track for the first time since I got my heads rebuild last fall with screw-in studs and roller rockers, valve job etc...
At about 330ft, it started missing and breaking up really bad and by the 1000' mark it was popping through the carb. I'm 99% sure the cam lobes are wiped out judging from how it sounds and is acting.
Before any of this happened though, I was seriously considering selling the car this summer. My question is do replace the cam and lifters first or just sell the car as it is and tell potential buyers what it needs? I know it's not worth as much as it would be running correctly but is the added expense of fixing it worth it just to sell it?
import slayer is offline
Old 06-29-2014, 10:32 AM
bluebeastsrt
bluebeastsrt's Avatar
I would take a step back and find out whats wrong with the car before I did anything.
bluebeastsrt is offline
Old 06-29-2014, 01:50 PM
import slayer
I will, but I'm 99% sure it's a wiped cam. I've heard that sound way too many times.
Old 06-29-2014, 04:25 PM
Maxwelhse
Maxwelhse's Avatar
I'd replace the cam or sell it as a roller if you're positive that's what it is. You'd probably make more on the sale if it ran properly.
Maxwelhse is offline
Old 06-29-2014, 04:35 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
wiped cam is not the only thing that'll do that, you need to run a compression test, then leak down and if that yields no results run a vaccum test and watch needle fluctuation that'll indicate valves not opening far enough then pull rocker rover and watch movement of rockers........bent push rods, bent valves, burnt valves and issues with rocker adjustment can all cause the same issues, so troubleshoot before jumping to conclusions......if it is a wiped cam, either you didn't break the cam in right or didn't use zddp additive for flat tappet cams
mjr46 is offline
Old 06-29-2014, 07:45 PM
import slayer
Bottom end was rebuild several years ago but I did NOT use a zinc additive. I only learned about modern oils not having zinc only after last Friday night. I do plan to start by pulling the valve covers and inspecting the rockers, pushrods, etc.
Compression readings were between 160-175 only a few weeks ago and vacuum was at 15, with a pretty much steady needle reading, considering the cam it has. This car only fires up before races and when it's at the track. Any other time, it sets in the garage and collects dust.
The only things that have changed within the last several months is the heads getting rebuild (at a good machine shop) and the addition of roller rockers, which I installed and adjusted and had somebody else verify that I did it correctly.
With all this being said, that's why I have it narrowed down to a wiped cam. I'm going to tear it all down anyway, but I'm pretty sure it's the cam and lifters.
Old 07-01-2014, 11:21 AM
gambling209
gambling209's Avatar
heard it before? it is my uinderstanding that cam wipeout is mostly a new breaking thing? i know plenty of people running their flat tappet cams hard and no problems and no zinc.
gambling209 is offline
Old 07-02-2014, 11:41 PM
tinman
tinman's Avatar
Check the cam with a dial indicator on the rocker arms, if it shows the lift being what it's supposed to be then the cam is good.....
tinman is offline
Old 07-03-2014, 07:56 AM
mjr46
mjr46's Avatar
only borrowed time
mjr46 is offline
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
mdg
10-01-2015 07:04 AM
UrS4
09-30-2015 10:13 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: Rebuild or sell?
