Started the tear down process and found this....
Old 06-30-2014, 06:56 PM
import slayer
import slayer's Avatar
Default Started the tear down process and found this....
So tonight I pulled the valve covers and the first thing I noticed was the oil inside the covers was milky. The second thing I discovered was #8 exhaust rockers was REALLY loose, there was at least 3/4 of play (up and down) between the pushrod and rocker and the adjuster nut was not loose!
The odd thing is that when I pulled the dip stick, the oil on it looked normal and was not milky like under the covers.
Why was the oil milky under the valve covers but not in the pan?
I'm going to assume that I had a coolant leak somewhere, which diluted the oil and wiped at least one cam lobe. I plan to tear into it further later on.
import slayer is offline
Old 06-30-2014, 10:04 PM
Maxwelhse
Maxwelhse's Avatar
I had an S10 that sort of did that. Milk in the fill cap and nothing on the dip stick. Since you're rebuilding I wouldn't worry about it too much. Probably something to do with the SG of the "milk" vs. oil and it not being "that" bad yet.
Maxwelhse is offline
Old 07-01-2014, 03:16 AM
bluebeastsrt
bluebeastsrt's Avatar
I agree. Since your tearing every thing down it really doesn't matter. If it was a leaking head gasket That's something you'll replace in the rebuild. I found a lifter valley full of dirt when I tore my engine down so you can expect a few suprises.
bluebeastsrt is offline
Old 07-01-2014, 08:10 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I always thought it was from condensation and I've never worried about it. Almost every car I've owned has done that.
Old 07-01-2014, 10:50 AM
Maxwelhse
Maxwelhse's Avatar
^^^that's totally possibly too depending on how much is in there.
Old 07-01-2014, 02:51 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
pics..
mjr46 is offline
Old 07-01-2014, 07:36 PM
9550's Avatar
did it look like this?
9550 is offline
Old 07-02-2014, 01:31 PM
95gtconvert
95gtconvert's Avatar
my truck had that but it was a tbi 350 with hard miles on it and I had just done head gaskets so needless to say I was a bit upset so I cleaned it up and it was fine after I ran seafoam through the oil before I changed it
95gtconvert is offline
djbigskrilla
09-20-2022 01:04 AM
dubarado
12-23-2015 01:16 PM
Urambo Tauro
09-07-2015 12:47 PM
mtxplod
08-29-2015 01:43 AM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Started the tear down process and found this....
