1.7 rockers
Old 07-01-2014, 12:39 AM
84CopperGT
84CopperGT's Avatar
Default 1.7 rockers
Do 1.7 roller rockers need a tune? I am trying to get around 200 rwhp without spending too much money. Trying to save up for a built engine but want some fun along the way.
84CopperGT is offline
Old 07-01-2014, 03:17 AM
bluebeastsrt
bluebeastsrt's Avatar
No they don't require a tune.
bluebeastsrt is offline
Old 07-01-2014, 07:12 PM
reldla1996
reldla1996's Avatar
I second, no tune required. One of my early mods, and you will note the difference.
reldla1996 is offline
Old 07-02-2014, 02:00 AM
84CopperGT
84CopperGT's Avatar
are there any that fit under the stock valve covers?
Old 07-02-2014, 07:40 AM
bluebeastsrt
I don't think after market roller rockers will fit. You'll have to research this but I think the stamped 1.7 rockers from a 351 motor will clear. They should be a lot cheaper also.
Old 07-02-2014, 06:44 PM
reldla1996
reldla1996's Avatar
I originally used Crane Cobra 1.7 roller rockers, and more recently comp ultra gold 1.7 roller rockers, both under the factory valve covers - which I still use. I had to remove the oil baffle to fit the Crane Cobras, and had to grind a little bit to clear the ultra golds, but they fit.
Old 07-02-2014, 07:26 PM
9redfox3
9redfox3's Avatar
They will give you alittle more lift ! I used the original 93 cobra valve covers with mine. Here's a few pics..
9redfox3 is offline
Old 07-02-2014, 08:19 PM
84CopperGT
84CopperGT's Avatar
Did removing the oil baffle do anything besides give clearance?
Old 07-02-2014, 09:33 PM
reldla1996
reldla1996's Avatar
I never had an issue after removing the oil baffle, but I've read other people complaining about it.
Old 07-02-2014, 09:37 PM
84CopperGT
84CopperGT's Avatar
So the worse thing that can happen is I need to buy a set of valve covers?
Quick Reply: 1.7 rockers
