rev limiter on an 05 mustang
Old 07-01-2014, 11:39 PM
ocorral20
ocorral20's Avatar
Default rev limiter on an 05 mustang
hey guys i have a friend who has an 05 mustang gt..
i think the rev limiter is pretty low..
i also have an 05 gt..
jusst wondering what the stock limiter is set at if there even is one?
i just got my car so i dont know..
let me know thanks... just want to know if its been tuned or if it just comes like that
ocorral20 is offline
Old 07-02-2014, 01:35 AM
danzcool
danzcool's Avatar
stock rev limiter is at 6250 RPMs for 05-09 GTs
danzcool is offline
Old 07-06-2014, 07:25 AM
Nuke
Nuke's Avatar
Yes, stock is 6250. Brenspeed set mine at 6800 which i thought was a bit high. Ive been running it set at 6500 and i still bounce off it if im not paying attention.
Nuke is offline
Old 07-07-2014, 06:01 PM
algregory
algregory's Avatar
Rev limiter can be fun! I was North bound on Hwy 1 North of Bodega Bay where the road is tight, twisty, and slow ( for most people) and I was jammed up behind a "most people" saw my opportunity, very short stretch/opportunity, hammered the throttle, I was alongside the "most people" and the rev limiter kicked in!
Last edited by algregory; 07-07-2014 at 07:05 PM. Reason: Got my towns mixed up, its been awhile
algregory is offline
Old 07-10-2014, 10:49 PM
psustangguy
psustangguy's Avatar
How high is a "safe" setting if one was to increase the rev limiter on a stock engine?
psustangguy is offline
Old 07-11-2014, 05:09 PM
jimkr
jimkr's Avatar
I believe that the stock setting is the "safest" setting. It's when you start adding mods that you would want/need to change the rev limiter. If you purchase a tune for a specific mod, the tuner will reset the rev limiter for a higher limit, depending on the mod. When you start adding mods, like headers, cams...etc. the redline of the engine will change, therefore the rev limit will also change. At least that has been my experience.
jimkr is offline
Old 07-11-2014, 05:18 PM
jimkr
jimkr's Avatar
Part of the problem with over revving an engine is valve float. Back in the 70s when manufacturers were lowering the compression ratios to 8:1 or less, valve float wasn't as much of a concern due to the simple fact that the piston wasn't traveling as close to the block deck. Now with higher compression, if you float a valve and it contacts the piston dome, breakage will occur, which is a very bad thing. Although, nowadays I don't believe valve float is as prevalent with overhead cams, although i believe it is still possible.
jimkr is offline
Old 07-13-2014, 01:08 PM
GCCBrian
GCCBrian's Avatar
Stock Limiter is 6,250rpm. With a BAMA or Brenspeed tune it's 6,800rpm's
GCCBrian is offline
Old 07-13-2014, 06:13 PM
Nuke
Nuke's Avatar
I'm sure Brenspeed feels that their setting of 6800 RPM is safe but I don't know and erred on the side of conservatism by resetting mine to 6500 as I stated above. I've bounced of it on numerous occasions with no ill affects. Personally, I probably should have set it a tad lower but whatever.
Nuke is offline
Old 07-13-2014, 08:38 PM
drewsky
drewsky's Avatar
I have a Brenspeed tune for about 5 years and my rev limiter is set at 6250 like stock.. I've hit it a few times. I know for sure it's not 6800. I'm tempted to call and ask if I should set it a little higher. Not sure if power is still climbing that high?
drewsky is offline
Diode Dynamics
28
05-26-2022 12:02 PM
FD725
08-23-2015 06:43 AM
daytooday
08-11-2015 09:22 AM
FD725
08-11-2015 03:43 AM
Quick Reply: rev limiter on an 05 mustang
