500 mile gear oil change after gear install?
Old 07-02-2014, 10:18 AM
Rocket254
Rocket254's Avatar
Default 500 mile gear oil change after gear install?
I have 4.10s going in next week. When I ordered the gear install combo from AM, they sent me 2 quarts of RP 75w90. After reading online, I ordered 3 quarts of RP 75w140.
Now, I'm left wondering whether I should order another 3q of 140 to do the initial break in, and replace it with more 140 after 500 miles. Can I get away with doing the break in with the 90 weight and 140 afterwards?
Rocket254 is offline
Old 07-03-2014, 07:53 PM
kn7671
kn7671's Avatar
There isn't really a "break-in" for gears when it comes to the oil, so there is no reason to wait for any certain number of miles. The correct oil weight is 75W-140, so just drain and refill with the correct oil weight when you have time.
kn7671 is offline
Old 07-03-2014, 08:50 PM
jz78817
jz78817's Avatar
the surfaces of the gears are hardened. There's no reason to change the gear oil after installing them.
jz78817 is offline
Old 07-03-2014, 09:41 PM
jz
jz's Avatar
When your car was brand new you didn't need to change the gear oil 500 miles later. Like the above have said, no need, just enjoy your new gears.
For what it's worth after installing my gears, I had an unrelated issued where I needed to change the gear oil about 1,000 miles after they were changed and there was no sign of metal in the oil when I drained it.
jz is offline
djbigskrilla
09-20-2022 01:04 AM
algregory
09-06-2015 05:52 PM
landomar2014
08-17-2015 04:27 PM
landomar2014
08-11-2015 06:39 AM
OBleedingMe
08-08-2015 12:02 PM
Quick Reply: 500 mile gear oil change after gear install?
