Edelbrock E Street with Hydraulic Roller Cam??? help please.
Old 07-02-2014, 04:48 PM
Tasteslikeink
Tasteslikeink's Avatar
Default Edelbrock E Street with Hydraulic Roller Cam??? help please.
I just recently acquired a set of Edelbrock E street heads for a decent price. I currently have a competition cam Pt# 35-304-8 cam. Edelbrock states that with these heads you can only use a flat tappet cam.
I've been reading...
The lift on the e heads can't exceed 0.550" of lift. My cams are max 0.533" lift on intake and exhaust. I know, thats pushing it... I've read of cams with 0.510" lift breaking valve springs.
BUT theoretically, this should work.... Theoretically..
I've also read that by replacing he valve springs with something like: http://www.jegs.com/i/K-Motion/571/K-750/10002/-1 will give me the ability to use my cams. Because these springs are good for .600" lift. I believe.
My question is, if i decide to go this route, do i need anything other than springs and valve seats???
I've had someone tell me I'd need new lifters, new push rods, as well as springs and seats.
I should add i haven't installed my cam yet. (been waiting to find a set of good heads for the right price.)
Any input is greatly appreciated.
Tasteslikeink is offline
Old 07-02-2014, 06:11 PM
Tasteslikeink
Damn.. forgot to add the car info... 95 GT
Old 07-02-2014, 06:51 PM
reldla1996
reldla1996's Avatar
The only way to be sure is to check piston to valve clearance. Those K motion springs you listed have a higher valve spring rate than you need for that cam, but that would not pose a problem.
reldla1996 is offline
Old 07-07-2014, 04:36 PM
Tasteslikeink
I'm taking the easy way out, sending it back and getting the E205 heads.
Old 07-07-2014, 10:32 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
over on the corral.net there is a whole thread dedicated to those who have tried to run roller cams with the e-street heads.......in short, don't do it!! there's more to it than just max lift........ramp rates on roller cams often differ greatly to that of flat tappet crap......which is why more seat pressures are needed, also depends on the lobe profile used
mjr46 is offline
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Edelbrock E Street with Hydraulic Roller Cam??? help please.
