Oil filter tried to win....but I wouldnt quit!
Old 07-06-2014, 05:54 PM
808muscle
808muscle's Avatar
Default Oil filter tried to win....but I wouldnt quit!
I have used Napa Gold filters for years. The last two oil changes I have had issues getting the filter off. I always lube the gasket and just hand tighten them and then give a quarter turn more. Both times the oil filter wrench, the band kind just crushed the filter. It took me 30 minutes with oil dripping all over me, busted knuckles and way too much lost skin to finally get it off. I used a razor knife to break the seal between the filter and the motor.
Looks like it will be Wix from now on. What wrench are you guys using to remove your oil filters? Was wondering how this one measures up?
http://www.autohausaz.com/search/pro...FYhafgodCKsA7A
Attached Thumbnails Oil filter tried to win....but I wouldnt quit!-img_20140704_152543213_hdr.jpg
808muscle is offline
Old 07-06-2014, 07:05 PM
Zeus2006
Zeus2006's Avatar
Yea, sometimes those filters don't want to come off. Especially if you paid a shop to do the last oil change.
I picked up a similiar style oil filter wrench to the one in the link you posted. Expect mine was local to me at a sears or ace hardware store and made by craftsman. I think it was $20, but I grew tired of dealing with the different size oil filters used on different cars, and having to carry multiple oil filter removal tools. Now, I am confident, no matter what car I but, the oil filter wrench will remove almost any oil filter from almost any car.
And I've already decided, if this wrench I have doesn't do the trick, I will just hammer a screw driver through the side of the oil filter and turn the screw driver untill the oil filter comes off. I almost did that on my last non-mustang car, but instead I went to the hardware store and picked up the wrench I have now. If this wrench doesn't work on a car/truck in the future, I'll just go caveman style. haha
Zeus2006 is offline
Old 07-06-2014, 08:17 PM
sbradle4
sbradle4's Avatar
I had to use the hammer and screwdriver method once on my GTO... That makes your butthole pucker just a bit... I was fully expecting with my luck that I would shear off half the filter and be screwed.
sbradle4 is offline
Old 07-06-2014, 08:32 PM
tbear853
tbear853's Avatar
I've done that a few times in the past!
I am sure it ws my fault for having tightened too far past gasket touch but sometimes 3/4 - 1 turn just doesn't feel like enough ...
tbear853 is offline
Old 07-06-2014, 10:27 PM
Rudolph Hucker
Rudolph Hucker's Avatar
never had problems with any car or bike tbh...i only ever do mine as tight as i can with 2 hands..
i use a cheap chain type to remove mine..
Rudolph Hucker is offline
Old 07-07-2014, 09:32 AM
moosestang
moosestang's Avatar
I've never had a problem with the screw driver method when all else fails. I've never crushed a filter with a band clamp wrench either.
Wix makes napa gold filters by the way.
moosestang is offline
Old 07-07-2014, 11:29 AM
ghunt
ghunt's Avatar
Honestly I've never had a problem getting a filter off this car- I wrap it in a paper towel and I can get it off by hand most of the time.
ghunt is offline
Old 07-07-2014, 11:42 AM
808muscle
808muscle's Avatar
It very well could of been my band clamp wrench. I put some pressure on that b#tch to get it off and she just crushed. I only hand tightened the new filter.
Old 07-07-2014, 01:46 PM
PNYXPRESS
PNYXPRESS's Avatar
I just had to use the screwdriver method for the first time on my GT. Not sure what happened to the filter that it tightened itself up either. I have always used the motorcraft filters on all my ponies and this was the first issue Ive ever had.
PNYXPRESS is offline
Old 07-07-2014, 02:13 PM
Art161
Art161's Avatar
Sometimes the wrench may be slipping a bit. You can wrap some sandpaper around the filter, grit side towards the filter. Then put the wrench over the sandpaper.
Art161 is offline
Quick Reply: Oil filter tried to win....but I wouldnt quit!
