Passenger Floor Wet
Old 07-08-2014, 02:28 AM
Valnar300
Valnar300's Avatar
Default Passenger Floor Wet
OK, I've got water coming in from the AC, its not draining through the firewall like it should. I've already unclogged it with a coat hangar and blew it out with air. That fixed it for a little bit, but now its clogged again. Is there any way to access the drain from the HVAC box side so I could pull out all the gunk thats in it? Preferably without pulling apart the entire dash.
Thanks!
Valnar300 is offline
Old 07-08-2014, 11:08 AM
kast1376
kast1376's Avatar
Thanks!
I have never had this issue, but I am guessing that since you used a hanger and blew it out, that all that did was blow/push the gunk higher up and in.
If you have a shop vac, I would try to build a reducer to fit the drain, and use the vac to suck out the gunk.
kast1376 is offline
Old 07-08-2014, 06:02 PM
Valnar300
Valnar300's Avatar
Thats where the leak drips out from
baddog671
07-26-2016 01:20 PM
b8checker
10-08-2015 12:55 PM
UrS4
10-03-2015 06:23 AM
b8checker
09-30-2015 07:11 AM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Passenger Floor Wet
