P0193 Fuel Rail Pressure Sensor
Old 07-08-2014, 01:36 PM
gnrpatience
gnrpatience's Avatar
Default P0193 Fuel Rail Pressure Sensor
Hello All,
Yesterday it was raining so hard while driving, I ran though a puddle not bad, then went to gas station to fill up the 'stang, engine light came on after I turn on the car. I got home and read the code it was P0193, after searching on the internet found out it can be the Fuel Rail Pressure Sensor, verified the car and could not see anything wrong. I check the gas cap since that was the two things before the engine came up, it had some drops on it, just cleaned. I cleared the DTC today morning before coming work, I noticed some weird noise when shifting at high RPMs from 1st gear to second gear and to third gear, like some spitting is not loud enough(I have CAI Intake) but driving seems good so far.
Just checked again and the engine light haven't come on again, what other recommendations would you give me to monitor or change the Sensor?
Does anyone have a diagram or pic where exactly is the sensor?
Any input is appreciated.
Thanks!
gnrpatience is offline
Old 07-09-2014, 01:10 AM
tx_zstang
tx_zstang's Avatar
It is located on the driver side of the fuel rail, mounted on top of the fuel rail with two bolts. There is a black vacuum hose running to it; carefully remove the hose and check for gas in the hose. If there is gas in the vacuum hose, the frps sensor is bad.
If you remove the sensor, be careful, as there will be pressure in the fuel rail and fuel will spray everywhere, and if anything is hot, it could start a fire.
tx_zstang is offline
Old 07-09-2014, 09:46 AM
gnrpatience
Thanks for the reply! I will review it this weekend and will make sure car is cold =).
Check Engine hasn't come back again would that mean I'm good or still can be something there ? Driving the car feels ok, it only spits a little different when shifting on high RPMs.
Old 12-25-2016, 12:51 AM
TorchredGT45
TorchredGT45's Avatar
Default Fuel Rail Pressure Sensor Trip
Hi there! Do you mind telling me what this ended up being? I had the exact same situation with the rain and fueling up and everything and received the same code. I'm worried but I don't have the symptoms of a bad sensor.
TorchredGT45 is offline
Jb145700
08-21-2022 06:37 AM
foxtrot
09-29-2015 06:32 AM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: P0193 Fuel Rail Pressure Sensor
