gas problems
Old 07-13-2014, 04:23 PM
my68
my68's Avatar
Default gas problems
i have a 67 mustang 302 , slightly built up msd.coil, and distributor, a 625 demon carb , platinum plugs set at 45 , gas mileage is about thirteen on highway at 60to 65 mph thinking of putting smaller jets in, i do a lot of cars shows that are a distance away any suggestion thank you for any help
my68 is offline
Old 07-13-2014, 08:44 PM
68gt/cs
68gt/cs's Avatar
all fixes cost a lot. aod, taller gears, efi, taller tires. and better gas does help alittle.good luck
68gt/cs is offline
Old 07-14-2014, 09:35 AM
bop11
bop11's Avatar
That was it back in the day of $0.45 per gal. No one look for millage. If you want economy with performance got to drop in a modern injected engine. Or, as 68gt/cs said taller gears and maybe convert to the Holley TBI.
bop11 is offline
Old 07-14-2014, 05:06 PM
Starfury
Starfury's Avatar
Step 1 is to properly tune the carb. Usually this requires some time on a dyno/sniffer at a shop, or some expertise and an air/fuel sensor installed in your exhaust. Until you tune the carb properly, you're likely to suffer driveability and/or fuel mileage problems.
Starfury is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
algregory
09-11-2015 11:44 AM
zachary1988
09-04-2015 03:04 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: gas problems
