unused plug under hood?
Old 07-14-2014, 07:33 PM
moosestang
moosestang's Avatar
Default unused plug under hood?
help me out here, what the F does this go to? I found this plug just under the low side refrigeration lines near the master cylinder. It looks factory and I sure don't remember putting it there anyway. I can't remember removing anything that it plugged into. It's coming out of the same wire bundle as the purge solenoid thingy. I was looking for refrigeration leaks when i noticed it. it's to short to reach anything.
I probably asked this same question several years ago and just forgot.
moosestang is offline
Old 07-14-2014, 08:33 PM
gmoran1469
gmoran1469's Avatar
Here's what mine plugs into:
Different color on the plug but the same plug, just two wires going to it.
gmoran1469 is offline
Old 07-15-2014, 02:07 AM
moosestang
moosestang's Avatar
yeah, i have a plug on that. the wires are a different color too. This extra connector comes out of the same wiring bundle as that connector in your pic.
Maybe something for an automatic? Anyone with a manual 06 have this extra connector? I can't remember removing anything during the whipple install that had an eletrical connector.
Old 07-15-2014, 07:44 AM
gmoran1469
gmoran1469's Avatar
Only other plug off that cluster goes to the side of my brake fluid res.
Old 07-15-2014, 01:26 PM
moosestang
moosestang's Avatar
Damn! That's what it is. I must have disconnected it when i installed the linelocks and forgot it. It didn't set a code. What is the purpose, to warn you when the fluid is low? Weird!
I even looked around the master cylinder and didn't see the connector.
Old 07-15-2014, 01:29 PM
gmoran1469
gmoran1469's Avatar
Maybe a temp sensor for overheating? Those are the only two things that I can think of. Low fluid or temp.
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
Urambo Tauro
10-05-2015 09:37 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: unused plug under hood?
