1990 wiring to 1991
Old 07-14-2014, 11:52 PM
tbone5448
tbone5448's Avatar
Default 1990 wiring to 1991
OK i thought i bought 1991 engine harness but i thinks its a 1990 because its a mass harness and got two plugs buy test plug brown and grey is there any way to make 1990 engine harness work with the 1991 dash
tbone5448 is offline
Old 07-15-2014, 02:09 AM
Im not sure I am following you here. What do you mean by " mass " ?
If you meant mass air flow, then both 90 and 91 are mass air flow cars. As far as the wiring goes , they should be the same between the 2 years.
The 87-89 are different from the 90-93
Old 07-15-2014, 08:55 AM
tbone5448
tbone5448's Avatar
I thought read somewhere where 1990 and 1991 wiring was different
Old 07-15-2014, 10:08 AM
tbone5448
tbone5448's Avatar
The 90-91 harness interchange with small mods. The 90 & 91 harness will work. For some reason the harness that connects the doors is different. Got this info off http://www.corral.net/ so does anybody if this is correct
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Dathan
10-05-2015 05:52 AM
14gt_Track
10-01-2015 02:47 PM
Quick Reply: 1990 wiring to 1991
