'89 GT A/C issues? Aargh!
Old 07-15-2014, 07:41 PM
Project 5.GO!
Project 5.GO!'s Avatar
Default '89 GT A/C issues? Aargh!
Can't take it any more!
Here's the problem: Something with the vacuum system is causing the A/C to blow out the defroster vents while I'm accelerating. It happens as soon as I put the gas pedal down, and about 5-6 seconds after I let the pedal go it will slowly go back to the normal vents.
It happens most when I'm accelerating at low RPMs, like when I have to slow down a little because someone pulled out in front of me, and then start speeding up again in the same gear. If I'm at high revs, like accelerating through second gear above 2500 RPM, it is less noticeable, or sometimes it won't happen at all.
I have checked all my vacuum hoses and everything looks like it is hooked up right and not cracked or anything. What's the deal?
Project 5.GO! is offline
Old 07-15-2014, 08:40 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
either a vaccum leak or the one way check valve out under the hood is either bad or missing.....lol, the canister for vaccum is in the fender on the passanger side towards the rear
mjr46 is offline
Old 07-17-2014, 07:14 PM
Project 5.GO!
What does this check valve look like? Is there anything I can do to circumvent the problem while I figure out where the leak is?
Old 07-17-2014, 11:02 PM
mjr46
mjr46's Avatar
follow the vac line that goes into the firewall by the evaporator lines......check valve will be inline with it
mjr46 is offline
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: '89 GT A/C issues? Aargh!
