Cutting out in boost...maybe detonation?
Old 07-16-2014, 07:51 AM
OKIEMUSTANG
OKIEMUSTANG's Avatar
Default Cutting out in boost...maybe detonation?
I need some help... I have a 95' 5.0 with a vortech v2 6-7lb boost, FMU, vortech BTM, trex fuel pump, stock 19lb injectors. It seems when going into boost, at or around 3500-3700 rpm range i start getting a little cut out... possibly detonation?
I am not sure, i have my initial timing set at 5* with spout removed.
I have my BTM set at about 1-3/4.
OKIEMUSTANG is offline
Old 07-16-2014, 06:10 PM
bluebeastsrt
bluebeastsrt's Avatar
your spark plug gap is probably to wide and your getting the spark blown out. I had this issue on a turbo car.
bluebeastsrt is offline
Old 07-16-2014, 07:48 PM
OKIEMUSTANG
What should the gap be? Any idea if my timing sounds about right?
Old 07-19-2014, 08:07 AM
uedlose
uedlose's Avatar
about .032 then you could move up or down from there. timing sounds ok
uedlose is offline
Old 07-22-2014, 11:56 AM
luckythirteen13
luckythirteen13's Avatar
its not detonation, your timing is too low
luckythirteen13 is offline
jwog666
12-27-2021 08:09 PM
piotrek53
10-13-2015 06:54 PM
jrrhd73must
10-02-2015 09:17 PM
mdg
10-01-2015 07:04 AM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
Quick Reply: Cutting out in boost...maybe detonation?
