Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: Air Conditioning Diagnostics
Guide to diagnose trouble and recommended solutions
AC/Cooling Fan Issues?
When you turn your AC on, the cooling fan should come on in the engine compartment. Mine does...but only runs for a while, then turns off, then comes back on, then off. It continues this cycle. Isn't it supposed to run ALL the time?
The reason I ask, is we hooked up some gauges to the AC system and went to add freon. When the fan came on, it blows colder air and the pressure on the gauges is in acceptable levels. When the fan cycles off, the air coming out of the vents warms up noticeably and the pressure on the gauges goes up considerably.
With the AC off, the fan came on when it got up to operating temperature and ran for a bit, then turned off and the vehicle isn't overheating.
Trying to figure out if this is normal....
Sounds "normal" as long as the car isn't running hot. The (extra) gauges you hooked up may be reading more accurate than the car technically needs. The fan should come on when the car is at temp and the AC on. When cruising maybe off and on, and when at a stop or stop and go city traffic stay on. That's been normal for me for 5 plus years. However I have a Brenspeed tune that runs the fan constantly when the engine is warm.
Car isn't overheating at all. I was just under the impression that the fan should be on at ALL times when the AC is on. Your fan doesn't run constantly when the AC is on either than drewsky?
It does now with the Brenspeed tune. It's on high speed constantly when it reaches full temp. If I recall correctly, prior to the tune it would kick on and off low speed/high speed. It's also hard to tell if it shuts off when on the freeway. Just cause you can't really hear it. As long as there is no issues with the AC and overheating I wouldn't stress it at all.
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
