DARN Starting Issue Again!
Old 07-18-2014, 06:18 PM
jonahdeich
jonahdeich's Avatar
Default DARN Starting Issue Again!
So I let my 289 sit for 3-4 weeks after driving around town. It ran perfectly when I parked it, but off course now it won't! I am getting spark and the car fires up when I pour gas into the top of it for a few seconds.... I have a edelbrock 1406 and sat for about 30 minutes cranking over the engine and pumping the gas until the battery got low.... The batt is on charger now so I want to figure this out. NO fuel is squirting into the bowl when I pump the gas but fuel has made it to the pump and their was a little fuel in the line that connect to the carb. I beat on the carb with a screwdriver with no luck. Fuel to the carb but not in the bowl Please help me! I am a little embarrassed because I had this problem before and my mechanic took the car for a while and got it working.... I CANT.... PLEASE help!!
jonahdeich is offline
Old 07-18-2014, 07:12 PM
barnett468
barnett468's Avatar
hello;
remove the coil wire.
pull the hose off the carb and stick it in a container.
have someone turn the engine over or jump the solinoid as you watch gas come out the hose.
it should hurl like old faithful. if it just trickles you have a pump, filter, line or low gas problem.
if it does hurl, your carb is the prob.
barnett468 is offline
Old 07-18-2014, 07:15 PM
jonahdeich
jonahdeich's Avatar
Thanks will try tomorrow and tell you the results!
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
drfister
05-03-2018 10:38 PM
Calizic
08-28-2015 01:46 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: DARN Starting Issue Again!
