Finding TDC
Old 01-06-2004, 05:40 PM
go300mph
go300mph's Avatar
Default Finding TDC
How can I easily determine when #1 is at TDC I can get close ie; the rush of air out the spark plug hole when the piston is coming up but I am concerned the pointer is the wrong one and therefore irrelevant.</P>
How do I make sure it is TDC and not just close.</P>
Mick</P>
go300mph is offline
Old 01-06-2004, 06:16 PM
bmorrisj
bmorrisj's Avatar
Default Finding TDC
stick a screwdriver in the #1 plug hole and whatch as it gets pushed out and no longer moves...btw dont get the scredriver stuck between the piston and the airpump hose...
bmorrisj is offline
Old 01-06-2004, 07:18 PM
mkspeed26
mkspeed26's Avatar
Default Finding TDC
</P>
where did you get that avitar??? it is the best on the site IMO. </P>
and that works for finding TDC</P>
mkspeed26 is offline
Old 01-06-2004, 11:49 PM
n2o44
n2o44's Avatar
Default Finding TDC
are you saying like using a degreeing wheel with the heads on , your just turning the damper , then yeah a rush of air will come out much stronger then the exhaus one . or you can use a stick i guess <IMG src=smileys/smiley2.gif border="0">
n2o44 is offline
Old 01-07-2004, 01:36 AM
351cleveland4v
351cleveland4v's Avatar
Default Finding TDC
To find TDC you can use the screwdriver and stick in the #1 hole and bump the engine over until the piston is all the way up but don't let it go down any or you can stick your thumb or finger over the #1 hole and wait for it to get blowed off the hole but be quick not to let it go down also be careful not to confuse the compression strokewith the intake stroke it will suck onyour finger a littlenot blow it offalso on true TDC both intake and exhaust valves will be closed after finding true TDC take off the distributor cap and see if the rotor points to #1 and check all other timing marks thiswill tell if it is correct be sure to pull off the coil wire so the engine doesn't start and becareful around the hole don't get pinched the chances are slim of getting pinched but play it safe.</P>
351cleveland4v is offline
Old 01-07-2004, 01:44 AM
BLKSTANG9879
BLKSTANG9879's Avatar
Default Finding TDC
You can do the screw driver thing. Or put a tissue on top of the port. When it blows off you got it. But the screw driver thing is alot better.</P>
BLKSTANG9879 is offline
Old 01-07-2004, 11:00 AM
go300mph
go300mph's Avatar
Default Finding TDC
I was told of a tool that you screw into the spark plug hole and hand turn the motor over and stop when it bumps into tool, mark balancerthen turn backwards until it bumps again then mark balancer again the point halfway between the two marks on the balancer is true tdc. Anyone know the where abouts of such a tool where can i buy one?</P>
I ask since I have some concern the tdc pointer on my motor is not the correct one.</P>
Mick</P>
go300mph is offline
Old 01-07-2004, 01:10 PM
bmorrisj
bmorrisj's Avatar
Default Finding TDC
wouldnt that make the #1 piston in the down position?
bmorrisj is offline
Old 01-07-2004, 01:56 PM
go300mph
go300mph's Avatar
Default Finding TDC
I think they mean half way between the two points the other way (the short way)</P>
sounds like an easy way to id tdc on your balancer </P>
Mick</P>
go300mph is offline
Old 01-07-2004, 02:22 PM
bmorrisj
bmorrisj's Avatar
Default Finding TDC
no i like my idea better <img border="0" src=smileys/smiley17.gif border="0"> ....
what would happen if TDC was set on the exhaust stroke? <img border="0" src=smileys/smiley5.gif border="0">
bmorrisj is offline
Quick Reply: Finding TDC
