Long tube header HP comparison
Old 12-24-2005, 04:10 AM
tradetheoex
tradetheoex's Avatar
Default Long tube header HP comparison
Has anyone seen horsepower numbers for the following long tube headers? I'm trying to decide between the stainless steel offerings in the marketplace. I'm not going for the Hookers becuase they only come in mild steel. I live in New England. Rust, Rust, Rust!
JBA Longtubes w/ catted h-pipe
Dynatech LongTubes w/ catted h-pipe
Kooks Longtubes w/ catted h-pipe
Stainless Works w/ catted h-pipe
tradetheoex is offline
Old 12-24-2005, 07:45 AM
Thump_rrr
Thump_rrr's Avatar
Default RE: Long tube header HP comparison
Here is the dyno results for the JBA Longtube Headers. It was performed by Pauls High Performance.
JBA Dyno Sheet
Just for your info the JBA's will require a new mid pipe either catted or catless. You will also require firmer engine mounts to prevent the motor from torquing and rubbing the headers on either the frame or the steering shaft.
Both Steeda and Prothane make engine mounts for the 05.
I went with the JBA Titanium Ceramic Coated Headers.
Thump_rrr is offline
Old 12-24-2005, 11:08 AM
spyder7724
spyder7724's Avatar
trade
i live in MD and we get our share of crappy weather. not as much snow but lots of ice/mix and the dot here loves salt! i feel the same about rust but if you get the hookers coated they will not rust since they are coated inside and out. mine look great. i have used coated headers since htc/jet-hot was introduced 15years ago and have never seen any rust. the coating is also worth a few hp so even if you decide to go with jba get them coated every little bit counts. jba claims 23hp hooker claims? but tube size and length is almost identical to jba so give them 20hp. watch for dynatech and s/works i think they use a 1 3/4" primary tube. this is a little big for our engines.
spyder7724 is offline
Old 12-24-2005, 11:33 AM
mash2k
mash2k's Avatar
Are any of the headers out there CARB approved and smog legal? I think keeping the car smog legal is important but I really want some headers on my car.
mash2k is offline
Old 12-24-2005, 03:11 PM
Twister086
Twister086's Avatar
the jba cat4ward shorty header are the only ones i know bout that are smog legal 50 state... they are the best shorty header but they arent longtubes thats for sure.
Twister086 is offline
Old 12-25-2005, 12:53 PM
mash2k
mash2k's Avatar
Yeah, shorties aren't worth the money in comparison to the stockers...I will get some LT's as soon as they are smog approved. Unless you trailer your car to the track, removing the smog equipment just isn't worth the headaches.
mash2k is offline
Old 12-25-2005, 07:50 PM
spyder7724
spyder7724's Avatar
there is virtually no smog equipment on this car. the only thing to worry with is the cats. other than that the VCT does the rest. no egr system or air pump to deal with...i love this car...thank you ford!!
Old 12-25-2005, 09:00 PM
mash2k
mash2k's Avatar
You're right spider, it is great to have hardly any smog equipment in order to run clean. These are really good cars. I do see a lot of people dumping the cats in order to get a few extra HP. Not sure I think that is such a great idea. Keep it legal, keep it clean, less headaches in the long haul.
mash2k is offline
Old 12-26-2005, 12:12 AM
spyder7724
spyder7724's Avatar
yeah i agree mash i would not have removed mine but the long tubes basically took the place of them. i may consider getting the jba or just going to my dads and welding some high flow cats on my hpipe. the stock ones flow great and why screw up the air when you don't have to.if only this thing was a flex fuel car...then we could get freaky with boost and timing running on ethanol and still be super clean...green peace may even sponsor a race car.
Old 12-26-2005, 04:18 AM
tradetheoex
I found some dyno info on the Stainless Works longtubes w/ cats. I'm not sure if they are the 1 3/4 or 1 5/8 size primary tubes.
http://www.bmrfabrication.com/05Must...204.6%203v.pdf
Quick Reply: Long tube header HP comparison
