Track times & Time Slips
Old 03-14-2014, 08:04 PM
  #381
lindertw
lindertw's Avatar
started racing in 2013, here's some of my runs:
16AUG13 @ MIR: 12.814 @ 106.36, with a 1.75 60' and backed it up with a 12.954, 1.855 60' @ 106.52mph.
16SEP13 @ Mason Dixon: best of 12.66 @ 107.25, with a 1.77 60'
18OCT13 @ MIR: 12.425 @ 108.93, w/1.67 60'. backed it up with a 12.463 @ 108.68, 1.69 60'
08NOV13 @ MIR:
384CD93E-D64A-4383-8D4F-2BC83E4CADC1-700-00000297CEAE2BC7_zps058fdb75.jpg?t=1383968792
itching to get out this year... picked up a set of 15" Weld RTS fronts and have a bit of weight reduction planned...
'05 mustang gt: cj springs, strange adj struts/shocks, M/T et street bias ply tires
lindertw is offline
Old 04-14-2014, 08:32 AM
  #382
travisr6
travisr6's Avatar
Default 2013 Mustang ET
Ran at Thompson for the first time in my '13 CS, I'm Car #73:
2013 Mustang GT California Special
6MT
3.73
Axle Back Mufflers
K&N Drop In
Stock Wheels w/ Pirelli Zero Nero summer tires
travisr6 is offline
Old 04-15-2014, 01:11 PM
  #383
25bduse
25bduse's Avatar
08NOV13 @ MIR:
Why such big fronts?
25bduse is offline
Old 08-10-2014, 11:01 PM
  #384
dacampora
dacampora's Avatar
2014 GT Track Pack. This is my first manual transmission car. I picked up the Mustang about 3 weeks ago now, and I've since done about 10 passes at LVMS. My best time was 13.660 @ 105.41. It was 93 degrees out when I took that pass.
I'm looking to improve my 60ft time of 2.228. I launched at 3500rpm, but I get nervous and release the clutch too fast. I know I need to slip the clutch more. Also all 4 tires were at 35psi. Any tips on getting faster 60's and ET's?
dacampora is offline
Old 08-11-2014, 01:46 AM
  #385
outceltj
outceltj's Avatar
slicks and skinnies
outceltj is offline
Old 08-11-2014, 06:18 AM
  #386
lindertw
lindertw's Avatar
The increased rollout on 28" ET fronts in theory should reduce my 60' and overall ET. With my low power car, I'm looking for any advantage I can get.
It looks a little better with the 15" welds on the back (rear tires are 26" ET street bias ply):
lindertw is offline
Old 09-08-2014, 03:34 PM
  #387
MustangGTMark
MustangGTMark's Avatar
What's a good ET for a 2010 GT w/ track-pack. Recently bought one used and going out to Gainesville's track for the first, just interested in what I should be aiming for or expect.
MustangGTMark is offline
Old 09-08-2014, 06:33 PM
  #388
lindertw
lindertw's Avatar
I went to MIR 29AUG14 for Midnight Madness...
front struts set to full loose
rear shocks set to +3 clicks from full loose
3560 lbs w/driver
DA started near 1100 ft and worked down to 400 ft later in the evening (per drag times DA calculator)
1st pass rear tires set to 14psi, 6k rpm launch
2nd pass rear tires set to 14psi, launched off the limiter @ 6.5k
3rd pass rear tires set to 16.5psi, launched off the limiter @ 6.5k
all remaining passes rear tires set to 15psi, launched off the limiter @ 6.5k
best run of the night was 12.491 with a 1.642 60' (new best 60'). MPH was down all night, possibly because I was running less pressure in the rear tires(?) Mounted my gopro to the panhard bar to watch the tire at launch:
here are outside vids to go along with the above undercar vid:
fullspeed
slow motion
lindertw is offline
carid
07-08-2016 09:55 AM
97SN95GT
09-13-2015 09:45 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
whatsup62
09-03-2015 01:38 PM
tj@steeda
Steeda Autosports
09-01-2015 08:16 PM
Quick Reply: Track times & Time Slips
