How to open a locked trunk?
Old 01-19-2006, 07:37 PM
lemur
lemur's Avatar
Default How to open a locked trunk?
...without the key, of course. My 1965 is missing the key to the trunk. Is there any way to release the latch from inside the trunk? Thanks!
lemur is offline
Old 01-19-2006, 09:02 PM
dawtips
dawtips's Avatar
Default RE: How to open a locked trunk?
unscrew gastank from underneath, push up, reach in, unlatch?
dawtips is offline
Old 01-19-2006, 09:09 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: dawtips
Except the gas tank on a 65 unbolts from inside the trunk. [&o] Just call a locksmith.
Soaring is offline
Old 01-19-2006, 09:25 PM
6mustang6
6mustang6's Avatar
Sqeeze through from the rear seat, with a pair of pliers and a flashlight. Then find the arm that connects the lock, and the actuator and turn it.
6mustang6 is offline
Old 01-19-2006, 09:27 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: 6mustang6
I can just imagine your skinny butt crawling through there.
Soaring is offline
Old 01-19-2006, 09:28 PM
tylerdru
tylerdru's Avatar
Charles has the best idea!
yeah i could fit rather easily
tylerdru is offline
Old 01-19-2006, 09:36 PM
Soaring
I ♥ Acer
Soaring's Avatar
OK you skinny kids. Just hope the trunk isn't full of tools and replacement parts like mine.
Soaring is offline
Old 01-19-2006, 10:35 PM
6mustang6
6mustang6's Avatar
Glen i think i've said this a long time ago, but im no where near skinny. Im 5 foot 11 inches, and 236 lbs. Football tackle.
Old 01-19-2006, 10:55 PM
Soaring
I ♥ Acer
Soaring's Avatar
OK, let's assume you can get through the hole from the back seat. And, let's assume there isn't some heavy stuff in the way that won't fit through that hole so you can get a clear access to the lock mechanism. Now, once you get there with your trusty flashlight, you will be faced with this. The only possible way to get the lock to turn loose will be to take the two bolts out using a 1/2" socket. But, will that do it? Even if it did, and you managed to get the lock to turn loose, you still either have to have a locksmith make you a new key, or replace the mechanism with a new key. Why not save all that back breaking and frustrating experience, and just have a locksmith do the job from the get-go?
Soaring is offline
Old 01-19-2006, 11:08 PM
6mustang6
6mustang6's Avatar
needle nose pliers, reach in, and turn that little square in that hole. Bingo. Yeah, i was just saying, he asked how to get it open and i told him. Well, at least my impala works like that.
Quick Reply: How to open a locked trunk?
