Differences 1966 and 1967 Mustang
Old 02-18-2006, 02:31 PM
LCF
LCF's Avatar
Default Differences 1966 and 1967 Mustang
Hi, just had a quick question for the more knowledgeable. I've been looking at a 1966 or 1967 mustang, it has a new engine, transmission and interior and has lost its VIN plate over the years. The owner is not sure if its a 1966 or 1967 and I don't know enough about mustangs to tell myself. Just wanted to know, any tips for spotting the differences between the years visually? Either curves, badges, air dams or dimensions?
Much appreciated.
LCF is offline
Old 02-18-2006, 03:21 PM
Shifty101Easy
Shifty101Easy's Avatar
Default RE: Differences 1966 and 1967 Mustang
1966 and 1967 are very differnt looking. the 67 has a differnt rear end and front end than the 1966.
1966
http://www.musclecarcalendar.com/Car...FabFordsP5.htm
1967
http://www.homestead.com/quebecregis..._Coupe_R.L.jpg
http://www.carmemories.com/images/dbimages/534.jpg
Shifty101Easy is offline
Old 02-18-2006, 03:43 PM
atomsk680
atomsk680's Avatar
whats the vin say? if the first number is a 6, then its a 66, if its a 7, then its a 67
atomsk680 is offline
Old 02-18-2006, 03:46 PM
atomsk680
atomsk680's Avatar
didnt see that part about the vin, sorry
Old 02-18-2006, 04:23 PM
Soaring
I ♥ Acer
Soaring's Avatar
Look at the driver's side inner fender next to the shock tower under the hood for the VIN.
Soaring is offline
Old 02-18-2006, 05:36 PM
Volcom66
Volcom66's Avatar
the biggest diff is the rear if its concave (indented) where the lights and gas is then its a 67...the 66 is just flat
Volcom66 is offline
Old 02-18-2006, 10:15 PM
Twister
Twister's Avatar
almost EVERYTHING is different, all body panels, all chassis parts (except floor panels), even the suspension parts are different.
Twister is offline
Old 02-19-2006, 01:56 AM
dcohen
dcohen's Avatar
the 67's are a little wider than the 65-66's, the engine bay is also a little larger so you could drop a 351w in it and put all factory looking parts on it and not too many people would know the difference
dcohen is offline
Old 02-19-2006, 06:13 AM
LCF
LCF's Avatar
Thanks for all the answers, the easiest thing I could spot from the answers you guys gave was that the 1966 had convex tailights, while the 1967 had concave tailights. Just need to verify with the seller as I can't remember off the top of my head which way they were, and it should be solved. Much appreciated!
LCF is offline
Old 02-22-2006, 11:14 AM
LCF
LCF's Avatar
'66
LCF is offline
ShaneB26154
35
03-04-2021 04:05 AM
chain
08-17-2015 08:52 AM
robjh22
08-17-2015 07:35 AM
MtnMustang
08-16-2015 08:07 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Differences 1966 and 1967 Mustang
