fuel pressure on stock 5.0?
Old 02-22-2006, 08:59 PM
SiGGa
SiGGa's Avatar
Default fuel pressure on stock 5.0?
I'm going to be installing a new fuel pump/regulator on my '89 GT and i would be much appreciative if anybody could give me any suggestions on fuel pressure
the regulator i'm installing is an adjustable 35-90 PSI and i don't know what the car should be running stock, so if anybody knows that it would be a start, i'm also wondering if there is much play in the setting and what i could go to comfortably without changing injectors for now.
I'm anxiously awaiting edelbrock's completion and release of their pro-tuner EFI system (#3671)that was due out in spring of 05 but for now, as my fuel pump has taken a **** on itself, i'll start with a pump (edelbrock #17932)and regulator (#1729)
just for those who are curious my future plans to match this start include an edelbrock intake #2945, throttle body #3826, egr plate #3829, undecided cam - not too racey for the street but something that can be worked up to some competition at the drag strip, heads haven't been decided on either but im currently leaning toward edelbrock if not for anything but a matching top end
As for the bottom end, i'll send the car on down to Race Engineering for a wonderful couple weeks of valvetrain work and gutting replacing polishing porting boring and balancing, and to have any upper end work that i can't do such as installing my intake (which needs to be polished to fit as it is shipped raw)
i'm not looking to have the fastest thing at the drag strip, just the fastest streetable thing. The reason i'll be able to use the setup i'm going with on the street will be thanks to the pro-tuner package which should allow me to work all the wild stuff out of my motor enough to tame it on the streets, yet be able to tune quickly up to a much more raw-performance oriented set of parameters for a visit to the strip
When it's all said and done my '89 mustang should be able to shove her heavy *** easily into the low 12's completely N/A.
SiGGa is offline
Old 02-22-2006, 09:11 PM
Crazyfast50stang
Crazyfast50stang's Avatar
Default RE: fuel pressure on stock 5.0?
I dont know what you were writing cause I didnt read it all, sorry, but stock fuel pressure should be 38 psi
Crazyfast50stang is offline
Old 02-22-2006, 09:14 PM
SiGGa
SiGGa's Avatar
awesome, thanks that's one major thing i needed to know
can i get by with more? if so, how much more? like i said i don't want to have to change anything yet as it's already coming soon but i want to know how far i can push fuel pressure on a stock set-up
thanks again
SiGGa is offline
Old 02-22-2006, 09:27 PM
razarr69
razarr69's Avatar
what makes you think you need more? what mods you running?
razarr69 is offline
Old 02-22-2006, 09:39 PM
rsw007
rsw007's Avatar
stock H/C/I cars need less fuel. they come from ford rich. my n/a tune was 34psi
rsw007 is offline
Old 02-22-2006, 09:54 PM
86HOGT
86HOGT's Avatar
Interesting. I always thought they'd be lean for emissions during that era...
86HOGT is offline
Old 02-23-2006, 11:32 AM
SiGGa
SiGGa's Avatar
so did i..
no real mods yet so i think my question has been answered. Thanks every1
SiGGa is offline
Old 02-23-2006, 11:45 AM
rsw007
rsw007's Avatar
well every car is different. but i tuned my fuel pressure and timing on a dynojet dyno. n/a tune ended up being 17* timing and 32-34 psi fuel there was no real change in the two. so i stayed 34psi
here is the final run
https://mustangforums.com/photo.asp?...Type=6&apage=1
rsw007 is offline
Old 02-23-2006, 02:45 PM
nitrous_bob
nitrous_bob's Avatar
yup, rsw007 is right on the money.
you want to run as lean as possible to make the most power. (too lean is very bad, too phat just slows you down a bit though)
thats why most people don't go so lean. the tradeoff is worth not risking it.
and stock 5.0's run way phat. guys take a stock motor and add an intake , 24 lb inj, and a 255 pump and can't figure out why they are slower.
34-35 would probably be perfect, i have always been under the impression stock is 36 psi.
nitrous_bob is offline
Old 02-23-2006, 04:48 PM
rsw007
rsw007's Avatar
mine stock was 39psi. i put the gauge on it before i installed the adjustable regulator.
rsw007 is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
MEISTERSNFB
03-31-2020 07:50 AM
YoungStangsMan
09-05-2015 07:01 PM
timeformiller44
08-26-2015 12:03 PM
Soldier GT
08-12-2015 03:46 PM
Quick Reply: fuel pressure on stock 5.0?
