351 Mustang
351W vs. 351W HO
Old 02-26-2006, 12:08 PM
FastFox
FastFox's Avatar
Default 351W vs. 351W HO
okay, I was wondering what the difference is between a regular 351 winsor 4-barrel and a 351 winsor HO 4-barrel? What would I have to do to convert my 1970 351 Winsor 4-barrel into a 351 winsor HO? Thank-you for the help.
FastFox is offline
Old 02-27-2006, 11:47 PM
S351R13
S351R13's Avatar
Default RE: 351W vs. 351W HO
As far as the internals there is no difference. Your 70 model will actually have more compression and better camshaft.
S351R13 is offline
Old 03-06-2006, 03:46 PM
rwh129
rwh129's Avatar
Ford never made a 351W HO. Are you refering to the 351 Cleveland H.O.?
There is a big differance between the Windsor engine and the Cleveland blocks.
The 351W is basically a supped up version of the 302.
rwh129 is offline
Old 03-06-2006, 04:06 PM
grabbem88
grabbem88's Avatar
http://home.pon.net/hunnicutt/history_windsor.htm
here is a little history for ya.....rwh129.....sorry no cleveland H.O.
grabbem88 is offline
Old 03-06-2006, 10:33 PM
S351R13
S351R13's Avatar
Ford did make a so-called 351w HO. It went in police cars in the mid to late 80's. It wa labeled this way to give the impression that it offered more power than the regular production 351w in civilian passenger cars.
S351R13 is offline
Old 03-07-2006, 08:27 AM
rwh129
rwh129's Avatar
Fast Fox Here is a real link that refers to the 351HO engine.
http://www.boss351.org/HO.htm
The 351 HO engine was not availabe in 1970. It was only in the mustang during 1972.
The '72 H.O. has all the required goodies to qualify for authentic Boss status. Additional standard features include--
9 inch "N" case rear end
31 spline axles
Big input and output shaft transmission
Rev limiter
Solid Lifter Cam (.490 lift/275 duration) (D2ZZ-A)
Adjustable rocker arms
Aluminum Intake manifold (D1ZX-CA)
Dual Point Ignition
Oversize harmonic damper (D2ZX-AA)
High output Alternator w/ big pulley
Forged Pistons w/ one valve relief cut on top (D2ZX-AA)
VIN stamped on back Drivers side of block
Shot-peened & Magnafluxed forged 1041 steel Rods (D1ZX-AA)
180,000 PSI Rod Bolts (D1ZZ-A)
Aluminum valve covers
Heavy Duty Flywheel (D1ZX-AA)
Six quart oil capacity
4-Bolt Main Bearing Cap Block (D2AE-CA)
Crankshaft-- specially selected (D1ZZ-A)
Larger exhaust manifolds (D1ZX)
While most enthusiasts gloat over the awesome 11.7 compression ratio of the '71, they forget it would be almost impossible to drive one of these cars daily on pump gas. With the lower compression of the '72 model year, daily driving is much improved. Although the 3:91 gears yield to very poor mileage, I drive my H.O. daily. Before the engine was rebuilt in March, it averaged 13 MPG on a 400 mile round trip. Not bad for 3500 to 4000 RPM most of the time.
rwh129 is offline
Old 04-05-2007, 02:29 AM
johnbo
johnbo's Avatar
351 w HO's were available from 1984 thru 1990 in ford trucks, vans and bronco's.
johnbo is offline
Old 04-05-2007, 06:25 PM
Arrid Extra Dry
Arrid Extra Dry's Avatar
yeap ... i have a 351 W HO motor in my 85 f250
the only difference in them is that they have a little higher compression, and a holley 4 barrel.
instead of just having 160 HP, they have 210 HP
Arrid Extra Dry is offline
Old 04-09-2007, 12:22 PM
4Stangs
4Stangs's Avatar
John Bo and Arrid Extra are correct.
4Stangs is offline
Old 01-22-2011, 03:11 PM
tanner1494
tanner1494's Avatar
They did make a 351w HO beacuse i have it in my 86 ford bronco
tanner1494 is offline
Quick Reply: 351W vs. 351W HO
